Clutch issue & question
Old Dec 24, 2019 | 01:27 AM
Big_Al59's Avatar
Big_Al59
Was driving home in my 2000 ranger, 3l & 5spd . Came to a stoplight, pushed in clutch & truck acted like clutch was out. It kinda lurched & died, it restarted ok but now it won't go into any gear. Any ideas of what to look for before I take it to
a garage?
Old Dec 24, 2019 | 06:47 AM
f5fordgirl's Avatar
f5fordgirl
If you have the same pressure feeling to the petal as before, it could be the pilot bearing has locked to the input shaft.
Old Dec 24, 2019 | 06:50 AM
Kruse's Avatar
Kruse
Well, how does your clutch pedal feel with the engine off? Does it need the same push to get it to the floor? Can you move the shift lever around like you used? Your "not going into any gear" symptoms might be because your clutch is not disengaging?
I suspect your hydraulic slave system has failed, but I haven't heard all of your symptoms yet.
Old Dec 24, 2019 | 11:53 AM
Big_Al59's Avatar
Big_Al59
The clutch feels the same as usual, the shifter won't go into gear. Almost like clutch isn't pushed in except it doesn't grind.
Old Dec 24, 2019 | 11:56 AM
Big_Al59's Avatar
Big_Al59
It does feel the same. Also it's had a little squeak when letting off the clutch in first gear.
Old Dec 24, 2019 | 12:56 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
Have you checked the fluid level in the clutch reservoir under the hood. No fluid means a giant leak in the hydraulic line.
Old Dec 24, 2019 | 06:22 PM
Big_Al59's Avatar
Big_Al59
Just went over & looked at it, fluid is full. Clutch still feels normal but shift lever feels sorta like its locked up. It will move side to side but won't move forward or backward into any gear. Maybe a linkage issue?
Old Dec 24, 2019 | 06:28 PM
f5fordgirl's Avatar
f5fordgirl
No linkage issue, trans has lost all its oil and is now toast.
Old Dec 24, 2019 | 07:26 PM
Big_Al59's Avatar
Big_Al59
I can check tomorrow, it was ok 6 months ago & haven't noticed any leaks
Old Dec 27, 2019 | 07:17 PM
Big_Al59's Avatar
Big_Al59
Changed tranny fluid today & it was full before I drained it.
Have to research what to check next
Old Dec 28, 2019 | 08:08 AM
Dan Robertson's Avatar
Dan Robertson
Same thing happened to my old 98 Ranger. The issue was the pilot bearing. It piled up and locked the input shaft. The clutch disk was still over 50% with 235K on it. It only took . The only had to take 004 off at the machine shop to refinish the flywheel. Swapped I replaced the disk and pressure plate out anyway. We also put in a new needle bearing style pilot bearing instead of the bushing that came with the clutch kit. I gave the truck away at 272K when I upgraded to a 4x4. As far as I know, it is still on the road.
Old Dec 28, 2019 | 01:14 PM
Big_Al59's Avatar
Big_Al59
Thanks for the input, I'll have to look into that. Done a fair amount of miscellaneous repairs but never a clutch. Truck only has 100k miles on it & is 4x4.
Old Jan 3, 2020 | 02:01 PM
Big_Al59's Avatar
Big_Al59
Finally got it towed to our local mechanic, he said the throwout bearing was pretty bad & the clutch springs were broke. So it's getting a clutch kit, throwout bearing, pilot bearing, flywheel & pressure plate.
Stymied
21
Jun 13, 2016 09:23 PM
Gear619
Jul 26, 2015 12:56 PM
4inchlovin
Aug 10, 2013 10:16 PM
Mishka0204
Feb 19, 2011 09:49 AM
gaidin
Jul 7, 2003 11:41 PM
