clutch problems
Old Feb 17, 2011 | 09:05 PM
Mishka0204's Avatar
Mishka0204
clutch problems
I recently bought a 96 explorer 4.0 5spd nd its kind of a project, i know for a fact it needs a new clutch, but when i start it with the car in 1st gear, clutch pedal down nd i rev the engine you can feel the clutch pedal push back at you as the enginr revs. Thought this was weird just wondering what that could be a sign of. Thanks again, Alex
Old Feb 18, 2011 | 07:22 PM
F-series Fan's Avatar
F-series Fan
clutch not releasing fully, weak slave cylinder, broken pressure plate fingers, oily deposits on clutch plate, just to name a few. Does it grind at all when shifting into gear? Any noises?
Old Feb 18, 2011 | 07:29 PM
Mishka0204's Avatar
Mishka0204
No theres no grinding or resistance through gears
Old Feb 19, 2011 | 09:49 AM
F-series Fan
Any noise without shift attempts? while idling clutch released? depress clutch while idling any noise? don't touch the shifter while checking for any noises. Is the clutch slipping? I only ask cause you said It needs a new clutch.
