Ruined my rear diff
Old Dec 23, 2019 | 02:24 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Originally Posted by ShelbyHauler
I installed an "Add-a-leaf" to the factory springs, lifted the rear end 2". When I put the trailer on with WD. it drops the rear about 3-4
I am guessing the driveshaft vibration stater right after the rear add a leaf. By changing the vehicles ride height you changed the drive shafts operating angle. If you do not measure and then shim the rear axle to spec you will get a drive line vibration, which as you are experiencing eventually ruins the t rear end and transmission.
Old Dec 23, 2019 | 02:30 PM
pirate4x4_camo
All the sources I am looking at state the rear axle has to be from a EX, SD F250 from 02 to 05?
  • 2002-2005 Ford Excursion - (10.50 RG), 4.30 ratio
  • 2002-2004 Ford Pickup f250sd (Super Duty) - 4.30 ratio
  • 2002 Ford Pickup f350sd (Super Duty) - 10.50 ring gear, SRW, 4.30 ratio (SRW), (tag V421 series)
  • 2003-2004 Ford Pickup f350sd (Super Duty) - 10.50 ring gear, SRW, 4.30 ratio (SRW), tag V421 series
there are more that which will work but to keep it simple, yes. any SRW F250-F350 from 99-2004 and 2000-2005 Excursion will work.
the difference between say a S410B and S412B model sterling axle in the Excursion is the configuration, In this case likely a limited slip versus open, Sterling gives each configuration a different model number. stick to the years I stated and it will work.
Old Dec 23, 2019 | 02:46 PM
trk pny's Avatar
trk pny
Not sure if this info helps but I have been researching some on my 01 / 6.8L / 2wd, for a rearend upgrade. From what I can find, Ford used the same "Sterling" rearend housing for the Excursions.
Some variances Ive seen are: gear ratios and the ring/pinion size. The 430 gear was on many of the early models but then when Ford had some customer whining on the gas mileage, they went to more 373 ratios.?
Ive also found that the ring/pinion on the gas models were the 10.25 and the diesels got the 10.5 (better able to handle the torque). Most people still just call the "Sterling" rearend a "10.5" but the size / bearings in them can be different.
A tech at Yukon gears told me the "diff id tag" will read 10.25 or 10.5 right before listing the gear ratio. per this, I know my 01 has the 10.25 with a non-posi 373 ratio. You can of course change out the gears and bearings as long as they all match (10.25 or 10.5)
As for the driveshaft being different , I have not found anything on this.
Old Dec 23, 2019 | 02:50 PM
ShelbyHauler's Avatar
ShelbyHauler
Add a leaf was added a year ago, no vibration until I recently changed the u-Joints. I have made 3 trips to Tn from Miami and had no vibration. I believe I have bent a U-Joint ear.
Old Dec 23, 2019 | 03:05 PM
pirate4x4_camo
could be, a driveline shop will be able to replace that and balance it.
Old Dec 23, 2019 | 04:35 PM
ShelbyHauler
Thank you for the info. Everything I am reading tells me the V10/6.8L has the 10.5" in both the 3.73 and 4.30. Mine has the 3.73 posi. I will have to crawl under and look for the tag to see what it has on it.
Old Dec 23, 2019 | 04:40 PM
ShelbyHauler
Originally Posted by ford390gashog
Your best bet is right here car-part.com remember that axle is super easy to get and superduty axles up to 2016 will also swap.
Sometimes, the given information can get a little confusing. :-)
But thank you all for your input.
Old Dec 23, 2019 | 05:58 PM
ShelbyHauler
2 tags, and yes, one of them has the "10 5" on it.
Old Dec 23, 2019 | 07:30 PM
Zack2001's Avatar
Zack2001
3.73 and 4.30 they take the same driveshaft. the only different drive shaft I am aware of is there are a few people who report having a double carden rear shaft but I have never actually seen one in person on a Ex or looked into which ex would have them. if your has a single joint on each end that is what the majority of Excursions have.
EDIT, this applies to the 4x4 models, I do not have first hand knowledge of the RWD shaft length. ( But I can look into if you like )
either way, I would take your shaft to a local driveline shop and have it balanced for your piece of mind however I am certain the vibration is a result of your increased ride height.
So this is unusual to have?
Old Dec 23, 2019 | 08:03 PM
pirate4x4_camo
not if you have a 2000-2002 V10 or a 2005 6.0
all my Ex's have been 7.3s
Old Dec 23, 2019 | 08:18 PM
pirate4x4_camo
[QUOTE=ShelbyHauler;19016442]2 tags, and yes, one of them has the "10 5" on it.
all Excursions use the 10.5
Old Dec 23, 2019 | 08:29 PM
ShelbyHauler
A tech at Yukon gears told me the "diff id tag" will read 10.25 or 10.5 right before listing the gear ratio. per this, I know my 01 has the 10.25 with a non-posi 373 ratio. ...
I thought so, but trk pny has stated differently, as noted above. ↑
Edit: but I see, his is an 01, and everything I have seen states I need an 02-05, so his may be different, but his statement about the gassers being 10.25 might be pre 02?
Old Dec 23, 2019 | 08:45 PM
  #28
ShelbyHauler
I found these on RockAuto, and they say they are the front shafts for a 4WD Ex. Is this on the front or the rear?
Old Dec 23, 2019 | 09:01 PM
  #29
Zack2001's Avatar
Zack2001
this is the rear.
Old Dec 23, 2019 | 09:45 PM
  #30
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
In 05, the SD trucks went to a 6" wider rear axle. Make sure you stay at 99-04 on the pickup truck axles if that ends up being your source. Those 05+ axles would create back spacing problems for your rims, and the brakes would be too big to fit anything smaller than a 17" rim.
00-05 Excursions are all the same as noted above...Sterling 10.5. I don't believe any 10.25 rear ends were put into any Excursions by Ford..maybe an owner installed one somewhere. You have to go back to pre-99 super duty trucks to get a 10.25
