Help with code P24A0
Old Dec 13, 2019 | 09:13 PM
Boaterguy's Avatar
Boaterguy
Hello everybody. My truck is a 2015 F250 CC 4X4, with 66K on it.
I pulled into my driveway last night and the "exhaust filter full" message came on as I backed into the garage. Driving in to work this morning, a regen started once the engine got warm. The filter went down to 50%, then the check engine light came on. Its code P24A0, some kind of temperature not at threshold thing.
Now I read some older threads on this and the fix seems to be split between reset it and no worries to you need a new catalyst system. As these trucks get older and people start seeing this code, I'm hoping someone has more info on it.
I live in the country, so my 27 mile drive to work is 2 lane roads at 60 mph with a few stop signs. The outside temp was in the low 40's. A few years ago, the dealer reflashed the PCM to solve the jack hammering issue I had experienced and all was well until now. I would appreciate any new info. Thanks for reading
Old Dec 14, 2019 | 06:19 AM
senix's Avatar
senix
can you read all four of your EGT probes? At temp and driving down the road EGT 13 and EGT 14 should roughly be the same.
As you increase your speed or give it fuel then it starts with EGT 11 and on down the line.
Old Dec 14, 2019 | 01:56 PM
Boaterguy's Avatar
Boaterguy
Originally Posted by senix
can you read all four of your EGT probes? At temp and driving down the road.
Unfortunately I cannot read those. My scan tool was bought several years ago when I had a V10 F350. It has 108 PID's in it and none of them are EGT sensors.
The truck is under extended warranty, but the closest dealer is 40 miles away. Diesels go thru their fleet department and, I guess they only have 1 or 2 techs because it takes about 3 weeks to get it looked at. I guess I am just wondering if I should reset it and see if the code comes back, because nothing is worse than bringing the truck in and they "can't duplicate the problem". But if I am reading this right, it looks like an EGT sensor is going bad?
Old Dec 14, 2019 | 03:15 PM
senix's Avatar
senix
My guess is one or more are reading erratically EGT 13 or 14. I would erase and see if the code comes back.
Iceman1777
6.7L Power Stroke Diesel
Aug 14, 2025 02:44 PM
Braaahp
Jul 10, 2016 10:00 PM
ggadwa
Apr 5, 2014 10:17 PM
tlawssss
Jun 23, 2012 07:34 PM
Dr.Dan
Dec 12, 2010 09:05 AM
