6.2L V8 Discuss the 6.2L V8
cold engine question.
Old Dec 6, 2019 | 04:11 AM
tjc transport's Avatar
tjc transport
i ain't rite
under 30 degrees when i start the truck it will run for 10 seconds or so then die. then to restart i have to hold full throttle and "clear it out" , it runs just like an old carb engine that is flooded.
i have replaced the purge valve twice now. it runs fine for a while, then starts acting up again. the current purge valve is three weeks old.
is there a temp sensor i am missing like the old GM 350's used that controls cold start? i had quite a few fuel injected 350's come in that acted like choke stuck closed, and changing the PCM temp sensor fixed them.
so i started thinking and am wondering if the 6.2 uses the same style system with two temp sensors, one for gauge and one for PCM?
Old Dec 6, 2019 | 07:46 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Have you scanned it for any codes.
If you don't have a reader I would get a bluetooth adapter and download the FORScan app, it will read about every sensor on the truck.
Denny
Old Dec 6, 2019 | 03:38 PM
tjc transport
i ain't rite
last code i got was from bad fuel cap three months ago.
this truck is a true head scratcher. besides the no cold start and eating purge valves, it also is only getting 7 mpg.
Old Dec 7, 2019 | 10:09 AM
leadmic's Avatar
leadmic
Have you replaced the fuel cap? It could be the cap is not venting properly and over pressuring or causing a vacuum in the tank effecting the purge valves.
Tomboy
May 15, 2007 10:30 AM
scouterspokane
Oct 15, 2005 05:25 PM
TimOttawa
Mar 19, 2004 11:19 PM
junkyarddog86
Bronco II
Mar 11, 2003 04:52 PM
