6.0 head testing
Old Jan 17, 2020 | 02:25 PM
Yahiko's Avatar
Yahiko
I would say "Cool Project" but I think that "Hot Project" fits it better.
Old Jan 17, 2020 | 03:11 PM
SmackDaddy's Avatar
SmackDaddy
Damn that is awesome work! Like I said, I wish we were neighbors, I’d have lots of projects for you! Haha
Old Jan 17, 2020 | 04:41 PM
Hartwig's Avatar
Hartwig
In fact I think we could do some great projects together :-)
But I have to correct myself on one thing: the thread of the block heater is not M27x2. It is a bit smaller. I have to measure it again.
Old Feb 14, 2020 | 01:26 PM
Hartwig's Avatar
Hartwig
it continues in small steps. I have made the fittings for the circulating pump and the aluminium plates with the rubber seal and the fittings are done.
I think in the next 2 weeks I can do a complete test, i.e. heat the head, pressurize the water side and at the same time pressurize the diesel side.
Old Oct 15, 2020 | 02:16 PM
Hartwig's Avatar
Hartwig
I finally found some time to continue with the test setup. A block heater is installed in the big brass tee on the right. I still have to fix a small leak, then I can do a warm pressure test.
How much pressure would you put on it? 30psi?
Old Oct 15, 2020 | 02:23 PM
SmackDaddy's Avatar
SmackDaddy
30psi should do it!
Old Oct 23, 2020 | 02:36 PM
Hartwig's Avatar
Hartwig
ready! Now I can also check the water circuit under pressure (30psi) and warm (160°F).
https://www.youtube.com/watch?v=o3FY...ature=youtu.be
nails023
23
Jul 3, 2018 11:14 AM
1979 Ford
South Dakota Chapter
122
Aug 1, 2017 07:19 AM
brokeasajoke
Nov 7, 2014 10:21 PM
capelo
23
Apr 15, 2014 04:21 PM
robjs111
Ford Truck Parts for Sale
Aug 20, 2013 08:43 PM
