I have heard dealers will not turn it off.....as it is an added mfg. safety feature....
However I have heard it can be turned off/disabled by using forscan!!
You are correct but the DRW trucks until 2017 came with the system disabled. I'm wondering if I can add the sensors to my 6 wheels and enable it. I know I can using FORScan but don't know if the truck will cooperate.
I wonder if you entered data for the two red asterisks if it would then display for 6 tires?
BCM 726-22-01 *1** ABCD **** TPMS Enabled AB=Front Tire pressure converted to hex, CD=Rear Tire pressure converted to hex
** changed to EF
BCM 726-22-01 *1** ABCD EF** Wonders if EF could be the other two rear tire pressure settings.
Not sure. There are 3 lines in the BCM for TPMS; Enable/Disable, 4 tires, 6 tires. There are the pressure threshold lines as well. Something tells me I can enable TPMS and select 6 tires and set the thresholds...
