Sponsored by: Real Truck
TPMS... 2012 F350
Old Dec 3, 2019 | 05:34 AM
Jacsent1's Avatar
Jacsent1
TPMS... 2012 F350
Wondering if anyone has been able to disable TPMS system completely. Can it be disabled using FORScan?
I have it set for 0psi using tuner but that only sets the system, as apposed to turning it off. So when I install wheels without sensors it sees no signal and shows fault.
tia
Old Dec 3, 2019 | 08:16 AM
Just Strokin's Avatar
Just Strokin
I do not know anyone off hand who has disabled it completely that post on FTE. I know the DRW has the TPMS module and it is disabled. I suspect you can use FORScan to disable it.
Old Dec 3, 2019 | 09:00 AM
WWR's Avatar
WWR
In the thread about adding pdl to an '08 I believe they said Forscan will do it.
SCT says their tuners will do it (verify model as they offer different products)
I keep meaning to find a way to disable on my '11, too
Old Dec 3, 2019 | 01:20 PM
Jacsent1's Avatar
Jacsent1
I can use the SCT to adjust and set psi to 0 but not disable the system
Old Dec 3, 2019 | 02:42 PM
Ginther's Avatar
Ginther
I used FORScan to "disable" mine on my 2015 F250. It seems to be turned off completely. No warning lights or anything. And my new wheel/tire combo does not have any sensors in them.
Old Dec 3, 2019 | 04:14 PM
WWR's Avatar
WWR
​​​​​​Interesting....so meaning you still need 4 good sensors, even to give a reading of zero each, I guess?
Old Dec 3, 2019 | 05:18 PM
96_F250_Deezal's Avatar
96_F250_Deezal
tell us what you did to disable the system.... which bits did you modify?
Old Dec 3, 2019 | 06:05 PM
Ginther's Avatar
Ginther
I used the info on this sheet.... Super Duty As Built Data
From this thread.... HERE
And modified the BCM code 726-22-01 as seen on line 30 of that spreadsheet.
I hope that helps.
Old Dec 3, 2019 | 08:13 PM
96_F250_Deezal
I hope that helps.
Huh, I have this sheet on my desktop and read it many times ... still missed that setting. Now I know.
Old Dec 4, 2019 | 05:23 AM
Jacsent1's Avatar
Jacsent1
I hope that helps
Fantastic info, even more than I was hoping for.
Once I get my new connection on Thursday I’ll give it a go let you know how I make out
Old Dec 4, 2019 | 06:03 AM
Jacsent1's Avatar
Jacsent1
Gremlins?
Well interesting occurrence this am.
as noted above, About two weeks ago are used my SCT tuner to turn my TPMS sensors down to zero psi And for two weeks I’ve been resetting and hitting the OK button on my steering wheel to clear the alert on my dash. Then I got this wonderful reply with all the directions and information on how to disable it using FORScan and was happy as PIS...
so this morning I went to my truck and I started it up and my low pressure warning light is no longer illuminated and I haven’t even started to do the modification identified in the posting above!! 🤔
vewwwy intwesting.....
Old Dec 5, 2019 | 04:26 PM
Jacsent1's Avatar
Jacsent1
TPMS DISABLED!!
Managed to disable TPMS system.
thanks for the help and info. Amazing help.
Old Dec 5, 2019 | 05:55 PM
WWR's Avatar
WWR
So in Post #11 you reported TPMS had gone MIA. Are we to assume it returned and you then disabled with Forscan?
Old Dec 5, 2019 | 06:16 PM
Jacsent1's Avatar
Jacsent1
yes that is correct, I was baffled and confused and spoke too soon about 70 km down the road it came back on
Old Jan 14, 2020 | 02:38 PM
mach8274's Avatar
mach8274
Good afternoon all. I am going to revive this thread a little. I might be the stupid one who wants to do the opposite. I noticed the other day while fooling around in FORScan, I can enable TPMS (I have a DRW) and have the choice of 4 or 6 sensors. Has anyone successfully added 6 sensors to their DRW and enabled TPMS? I have stock wheels/tires and have no intention of changing them. I know the 17 DRW has TPMS and was wondering if I can enable TPMS on a 16 DRW.
