E4OD stand alone controller
Old Dec 2, 2019 | 09:57 PM
Paul 92 f350's Avatar
Paul 92 f350
I have a 1993 f350 4x4 dually 7.5. My trans is in limp mode I believe. I have almost checked everything except the pcm. Coil packs are working. Thinking about putting a standalone controller on. Anyone have experience with them?
Old Dec 3, 2019 | 08:33 AM
merc460's Avatar
merc460
I am running an original compushift to control my E40D but I am running a cummins so I need it. It works as it should .In your case you should check for codes and repair any issues.The factory controller works well in a OE setting.
Old Dec 3, 2019 | 10:59 AM
Paul 92 f350
Thanks. After pricing them I think I will keep digging. Factory computer would be cheaper.
Old Dec 3, 2019 | 05:56 PM
humphrey169's Avatar
humphrey169
What is a compushift
Old Dec 3, 2019 | 06:01 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If you don't know why it's in limp mode installing another controller may not fix the problem.
The ONLY way to fix this is to read the codes.
Old Dec 3, 2019 | 06:21 PM
Briansshop's Avatar
Briansshop
I priced one up a few months ago, came to about $1300.
https://www.hgmelectronics.com/compu...sport-and-pro/
Old Dec 4, 2019 | 12:24 AM
Paul 92 f350
it has a solenoid 1 circuit problem. Cant remember the code right off . Trans shifts if I ground solenoids manually. Mlps , tps , relay, fuse, diode and wires to trans check out.
I didnt know how expensive they were when i posted. I will keep troubleshooting. OEM pcm would be much cheaper if that's the problem.
Old Dec 4, 2019 | 06:33 AM
Briansshop's Avatar
Briansshop
Paul, just for info,you can get a US Shift unit for around $500.
https://www.usshift.com/index.shtml
Old Dec 4, 2019 | 07:02 AM
jackietreehorn's Avatar
jackietreehorn
For that price, why not install a rebuild AOD or C6? Or whatever comes with a cummins 907...727?
350xsx
15
Nov 11, 2010 05:46 AM
van1989
May 25, 2009 11:24 PM
javi2001
May 20, 2003 06:38 PM
javi2001
May 15, 2003 04:53 PM
shuttlevalve
Feb 15, 2003 10:43 PM
