updated sync to 2020 software
Old Nov 28, 2019 | 08:49 AM
  #31
tortue71's Avatar
tortue71
Not a fan of these colors either. The stock blue in my 17' is just awful. I prefer the Lincoln theme with my tan interior. Can't believe that in 2019 we are still stuck with unchangeable colors and persistent bugs for years
Old Nov 28, 2019 | 10:58 AM
  #32
JHForman812's Avatar
JHForman812
i was in my coworkers lexus(brand new) the other night, guess what I couldn’t change the colors on it either, I’ll admit the UI is more fluid but you couldn’t pick colors. I changed mine to the Lincoln theme and still have the ford splash logo. Only place I can see a Lincoln logo is under settings where it shows the ford pass is a Lincoln logo
Old Nov 28, 2019 | 07:54 PM
  #33
kry226's Avatar
kry226
So I have found some broken features after upgrading today, neither one I'm crazy about.
1. No longer can you browse your USB folders in their entirety unless stopped.
2. Voice command operations are terrible now. So far in 10 minutes trying, it hasn't recognized a single command yet. I used to say, "Play Zac Brown Band." And it would play. All I get now is, "I didn't get that..."
I like the updated maps, but so far, I've gone backwards in capability. Wish I had my functionality back.
Old Nov 28, 2019 | 08:12 PM
  #34
JHForman812
i haven’t tried voice requesting music, I’ll give that a shot. I have yet to notice any functional loss. As far as usb goes I don’t use that either for music, I listen on Bluetooth or though my cable connected to my phone.
Old Nov 28, 2019 | 08:41 PM
  #35
kry226's Avatar
kry226
I just noticed no fuel prices can be found either. The rest of Travel Link seems to work fine. I did get it to recognize a couple of addresses in the nav.
Old Nov 28, 2019 | 09:33 PM
  #36
JHForman812
Ok went out and played with my truck for a quick min and not being able to play an artist, I came back in and looked up the voice commands for music. your specific issues seem to be related to USB music playing. All voice commands I tested worked fine for me. I do not have a USB drive full of music laying around to test your specific issue. I will look into the travel link issue when I drive my truck tomorrow. did you do the master reset after loading the software? ive actually had 0 issues with the features I use, and they respond faster than v3.0 did.
Old Nov 28, 2019 | 09:42 PM
  #37
JHForman812
Originally Posted by ForCal
That's great! Thanks for posting that. Does it enable ambient light control? Not color, but brightness. That's probably a hardware not software change one the 20's.
ive been digging into this and have had no luck, I can turn on the ambient lighting option, but it gives the multi color lights and you cant adjust the brightness. I don't have UCDS but I wonder if the firmware update would enable this. I pulled the asbuilt data from a 2020 using a vin I found online I copied every single line to my truck and it turned on the multi color ambient lighting instead of the birhgtness like we are looking for. I keep an eye on Livinitup spreadsheet hoping it will appear on there but it hasn't yet.
Old Nov 28, 2019 | 11:08 PM
  #38
kry226's Avatar
kry226
I did not do a master reset, but I also didn't see where that was required or recommended. Is that necessary?
The music commands have changed for whatever reason, and even when I follow the command cues, "Show music by _____," still nada. But it's counterintuitive that the system now prevents you from browsing your media folders at speed, but the command for the same music media is "show", which defeats the point of voice commands in the first place.
I have also noticed some lag, not much different from the 3.0 I upgraded from.
Old Nov 29, 2019 | 02:32 AM
  #39
Icelink's Avatar
Icelink
I read thru this entire thread, iam not a tech or computer guy, but with some of the things people are saying and how they see a brief flash of the Lincoln logo, something isnt right, I cant believe you guys would run the risk of bricking the system like the OP mentioned
This is definitely not for me, and am perfectly fine with my factory 2019 sync 3
Old Nov 29, 2019 | 10:35 AM
  #40
JHForman812
The master reset wasn't recommended in the first post, there was a few people who until they did a master reset weren't getting the logos from XM radio. it was just a suggestion I don't know if it will do anything for you. I did do it on mine.
Im not a computer expert either but I can answer why we see the brief Lincoln logo on occasion and only on shut down not at start up. Its because you told the system to change to Lincoln theme, but youre telling it via for scan you want a ford logo for the boot screen. it briefly looks up the Lincoln logo before switching to the ford that the software is telling it that it should be. if you keep it on the ford theme you never see the Lincoln logo. im sorry you cant believe we guys would run the risk but I evaluated the risk before doing this. its ford official software as far as I know and the system installs it just like if you went to the dealership. modding stuff is part of the fun of owning a vehicle, sorry these aren't mods you understand or approve of.
Old Nov 29, 2019 | 04:29 PM
  #41
muzhik's Avatar
muzhik
Thumbs up
Just updated... looks good so far, did master reset after update.
Thanks to OP and f150 forum Airborne_Ape for this awesomeness
  #42
mrgrayaz's Avatar
mrgrayaz
why are you posting in this thread?
Old Nov 29, 2019 | 04:41 PM
  #43
JHForman812
I personally went back to 3.3 today, I like the black night mode more than the blue night mode. I will say that the 3.4 looks more crisp than 3.3 I am actually researching jail breaking the sync software as we speak. I enjoy messing with stuff. I had the Lincoln theme on there, it looks good But wanted true black. I’ll keep playing around
Old Nov 29, 2019 | 04:56 PM
  #44
ForCal's Avatar
ForCal
What is 3.3? I have never done any updates to Sync since purchasing my truck. I haven't noticed any of the glitches some have posted about, so I have just left it as is. I am open to changing the theme or interface, and had been thinking about doing this most recent version until some negatives were posted.
Old Nov 29, 2019 | 05:08 PM
  #45
JHForman812
3.3 looks like 3.0 I’ve only noticed a few small changes in it vs 3.0, I get my contacts pictures on the screen now, and when I select nav, or phone, or settings or climate, the buttons change colors(settings is purple, phone is yellow, climate is blue etc) this might have been present in 3.0 but I really don’t remember seeing it. Other than that 3.3 isn’t much different than 3.0
