What is making this squeaking noise?
Old Nov 23, 2019 | 03:57 PM
Maillemaker's Avatar
Maillemaker
At first I thought it was the idler pulley. So I replaced it. Still squeaked. Got another one. Still squeaked.
I was about to replace the water pump, but then I noticed that the squeak is not in time with the pulley rotation - it is in time with the belt rotation. Every time the printed decal on the back of the belt goes past the idler, it squeaks.
I tried putting a drop of dish soap on the idler pulley - no change.
Could it be the tensioner itself squeaking as the thicker part of the belt goes by? I would not think the decal substrate was that thick.
I know it's not the water pump as when I remove the belt the water pump keeps turning from the other belt and it's silent.
I used a mechanic's stethoscope (what a neat gizmo!) and it's definitely coming from the idler mechanism - not the power steering pump and not the AC compressor.
Steve
Old Nov 23, 2019 | 06:49 PM
NICKSAN's Avatar
NICKSAN
Did you replace just the pulley or the whole mechanism?
Old Nov 23, 2019 | 07:25 PM
Steve460's Avatar
Steve460
Spay the belts with silicone spray or belt dressing and see if it goes away
Old Nov 23, 2019 | 10:19 PM
Maillemaker
Just the pulley.
Steve
Old Nov 23, 2019 | 10:49 PM
Maillemaker
OK, I did some googling and low and behold, this video let me trouble shoot it immediately. It's definitely the belt.
I was about to replace the whole tensioner mechanism. Now I see it's cheap belts.
Steve
Old Nov 24, 2019 | 05:02 AM
JWA's Avatar
JWA
I've used both Motorcraft and NAPA serpentine belts with good success---never a squeak or failure in over 200K miles three different 5.4's. Also used Motorcraft tensioners with similar results.
BTW Motorcraft can be had fairly priced through eBay and/or Amazon---well worth looking at when needing such things.
Old Nov 24, 2019 | 08:31 AM
Maillemaker
Does anyone know the Motorcraft part number for the belts for a 1990 E350 460 CID EFI engine?
One belt does fan, alternator, air pump.
Other belt does fan, AC, power steering.
Old Nov 24, 2019 | 01:29 PM
JWA's Avatar
JWA
Try RockAuto or NAPA---their belts are top notch quality too.
7racecar7
Modular V10 (6.8l)
Mar 16, 2015 05:54 PM
rblaine9000
Feb 24, 2011 07:40 PM
kuskye25
Mar 13, 2008 07:02 PM
Keepitrunnin
Jan 14, 2007 08:22 PM
gembeau
Apr 17, 2001 07:37 PM
