Belt / Pulley / or Pump Noise
Hello,
I have a chirping / squeaking noise repetitive.
I have a new belt on changed that about 6 months ago. I also cleaned all the pulleys with simple green then, brake cleaner, spun all the pulleys for noise and wobble and nothing seems out of place.
I did the water test and it stops the noise for a few seconds then it comes back, after that I tried to narrow it down to a specific pulley, it seems that when I spray brake clean on the top of the water pump belt location it goes away.
Anyone think changing the water pump pulley could cure it? it looks as if the belt has been slipping for some time as the pulley is very shiny.
Trying not to throw parts at it but if i did I would suppose waterpump pulley, then tentioner, new belt then, water pump...any ideas or obvious solutions?
Belt
it worked a few months ago, noise started to show up then got worse.
Groundpounder0331
01-25-2009 08:16 PM
gembeau
04-17-2001 07:37 PM
