Squeeling Belt
Old Dec 24, 2010 | 06:47 AM
rblaine9000's Avatar
rblaine9000
Squeeling Belt
I am starting to HATE MY TRUCK!!!!! I have been trying to find my squeeling belt issue! I have replaced my belt three times and my tensioner and my idler and my altenater and my power steering pump! the only pulley that I have not changed is my water pump pulley! would this be the magical trick or do I need to just throw a match at it!!!!!!! arghhhhhhhhh
Old Dec 24, 2010 | 07:15 AM
jt371's Avatar
jt371
______
Have you read this thread? This is a sqeak that some of us have. I personally have not dealt with a sqeel from a serpentine belt.
https://www.ford-trucks.com/forums/1...eo-inside.html
Old Dec 30, 2010 | 07:40 AM
rblaine9000
well I read it and a lot of it is the same and no comformations as to an exact cure? I have done everything in that post so I am just going to sell her I think and upgrade to a 6.4
Old Dec 30, 2010 | 07:46 AM
Kwikkordead's Avatar
Kwikkordead
I'm in the same boat since I put my new engine in.
New crankshaft pulley and everything.
Every morning the belt squeaks for about a minute then goes quiet.
Alternator, power steering pump with a new pulley, tensioner assembly, water pump.
The only rotating assembly that I haven't touched is the A.C. pump.
I'm beginning to suspect that the crank pulley is offset outward 1/4 inch or something.
Old Dec 30, 2010 | 10:28 AM
duck fan's Avatar
duck fan
Because racetruck
If anything this thread serves as a comfort that I am not alone...
Old Dec 30, 2010 | 10:38 AM
Kwikkordead
That's for sure!
Old Dec 30, 2010 | 04:01 PM
rblaine9000
Exclamation
well I did forget to mention that that tis how all this started for me! it would only squeek until warm but now it has gotten to the point of squeeking all the time so I dont know? if I find an eact cure I"ll post I have even replaced my power steering pump!!!WTF
Old Dec 30, 2010 | 04:29 PM
rblaine9000
well I feel like an idiot BUT>>>>>> check this out boys and you too kwikordead I found the problem and fixed her i think? I will let you all know in a couple of weeks or so but when I was posting last I remembered about changing that power steering pump and grabed my pulley intallation removal tools and noticed my belt was riding further back on the water pump pulley so I placed my removal tool on the pulley and pulled out a ways then tried, got a little better so I pulled out some more and tried her and !!!!!!!! NO SQUEEL!!!! I have adjusted this before but must not have been holding my tongue right so this is where you guys should be looking at miss aligned pulleys. furthermore I had a bearing retainer fall out of my altenator so this is the key boys (and girls) check all your pulleys for straightness and parallelism!!!! as I said at the begining I will reply to this after some time to info of a possitive fix!!! Thanks
Old Dec 31, 2010 | 12:40 AM
duck fan's Avatar
duck fan
Because racetruck
Its funny that you mention this. I actually have a new power steering pump pulley that I have been meaning to install. I am currently using an OBS pulley which has a slightly different offset than the Super Duty pulley. However, the squealing started well after the pulley swap.
Old Dec 31, 2010 | 08:49 AM
Kwikkordead
My belt was squealing both before and after the power steering pump replacement on mine.
I've tried to find a pulley that is off-set a little, looking down at it and also getting underneath and looking up.
Everything is on a flat plane.
Belt isn't getting chewed up on one side or anything.
I'm going to ignore it for now.
Old Jan 1, 2011 | 06:23 PM
rblaine9000
I used the same pulley? so I don't know what you guys are saying offset???
Old Jan 1, 2011 | 08:49 PM
Kwikkordead
All the pulleys have to be on the same "level".
Like if you laid them all on a table face down, then flipped the table up until it's verticle.
Old Jan 3, 2011 | 11:57 AM
duck fan's Avatar
duck fan
Because racetruck
What I was referring to is that I am currently using a PS pulley off a 97 7.3. It has a slightly different offset from the 99+ pulley. I have the correct one. I just haven't had time to deal with it.
Old Feb 24, 2011 | 07:34 PM
rblaine9000
no squeeel still!!!!
Old Feb 24, 2011 | 07:40 PM
Kwikkordead
It was cured by adjusting the power steering pulley outward a little?
nbtone
22
Jul 17, 2020 02:30 AM
medicbull
6.4L Power Stroke Diesel
18
Mar 10, 2013 12:09 PM
bmarkline
Sep 12, 2010 05:16 PM
Jrock909
Mar 21, 2007 12:26 PM
jstutz101
Modular V10 (6.8l)
Apr 7, 2006 05:19 PM
