Injector hot torque question?
Old Nov 21, 2019 | 07:39 AM
  #31
Bobcatbob's Avatar
Bobcatbob
As the OP of this thread, i would like to thank everyone for their input. I normally just search the forum to learn and solve problems. There are many other previous posts on injector bolt torque that were extremely informative covering, actual improvements, locktite, best torque wrenches, ect.
Old threads are great, but bringing up a topic again can sometimes add a new "twist" in the discussion.
Thanks to all for adding to our passion (brain defect) with these motors. Mine is 23 years old and I never dreamed then it would be my last truck.
Thanks again, Bob
Old Nov 22, 2019 | 04:09 PM
  #32
Bobcatbob's Avatar
Bobcatbob
https://www.ford-trucks.com/forums/1...one-right.html
This is probably the best tutorial if seen on injector install.
Old Nov 22, 2019 | 04:40 PM
  #33
Tedster9's Avatar
Tedster9
It isn't really unusual for fasteners to need retorques, if something is going to have access issues after assembly they might be safety wired, or maybe something like blue Loctite applied to threads. Why doesn't Ford do this?
Old Nov 24, 2019 | 07:03 PM
  #34
Bobcatbob's Avatar
Bobcatbob
Update:
Bought the A.C. Delco digital torque adapter.
All hold down bolts started to move at 90 to 100 inch lbs. Now I know they are tight.
As a bonus found a burnt glow plug pin at valve cover plug.
Don't have a clue if it quieted it down, but now I have peace of mind.
Bob
Old Nov 25, 2019 | 08:33 AM
  #35
brian42's Avatar
brian42
Veteran: Navy
It didn't make mine quieter as much as less chatter.
Old Nov 25, 2019 | 09:58 AM
  #36
Tugly's Avatar
Tugly
I use the same unit. don't trust those scratched numbers on the side of the handle, so I use the Delco to set the wrench, then do the torquing without it. This keeps my eyes on what I'm doing, and the configuration of the wrench simple.
Old Nov 25, 2019 | 05:34 PM
  #37
Bobcatbob's Avatar
Bobcatbob
You enlightened me on the A.C. DELCO adapter.
Hard to see the actual LED numbers & and hear the beeping change tone.
So, next time I will calibrate my Tetron inch/lb. clicker. But, it sure was fun to use regardless.
Thanks, again. Bob
keiseldiesel
23
Apr 13, 2015 06:17 PM
Rxracer27
17
Jan 5, 2014 04:59 PM
akmikek
16
Dec 8, 2013 11:04 AM
lalh20
Nov 24, 2012 07:57 AM
savage250
Oct 15, 2011 03:00 PM
