I can tell that no matter what I say you won’t be convinced. But just for the sake of it:
1. It would take the installer the same amount of time to defeat it as to install it. So, he’d have to flatbed it to a garage - and that anyone could do, and given enough time, defeat the system. That said, the installer doesn’t get the key. There are thousands of unique versions. The company will only provide keys directly to the owner and the process is a huge PITA that requires photo ID and the associated physical mailing address of the ORIGINAL registered owner and a check with their name etc. That said, I think it’s a pretty remote (and ridiculous) concern that a Ravelco installer will start stealing vehicles. I think I like my odds.
2. Viper restores remote iPhone lock unlock, GPS real-time location, geofencing alerts, CEL alerts etc, and the nice feature of a siren with a battery backup in case anyone breaks in (Ravelco would keep them from driving off). Different functions. Nothing to do with confidence in one or the other.
If it’s not for you - cool. I just scratch my head at why you’re so negative regarding a perfectly reasonable option - choices in the market are a good thing.
Originally Posted by F2502011
Why Viper too? You’ve probably got $1500+ in anti theft devices.
Not confident enough in the Ravelco system to just have that?
What’s to stop a Ravelco installer to start ripping off vehicles with the system installed because they understand it and how to defeat it?
Sorry to come across so negative. I’m simply trying to figure out if it’s worth spending $600 over $50 for the same protection. Why is Ravelco worth $500+ more than a basic kill switch?
Different devices, different purposes in my view;
The Viper + Smart Start is more of an intrusion alert system and is software based - a determined and knowledgeable hacker can override it just as they can with similar OEM electronic/software platform devices,
The Ravelco is hardwired at multiple points and cannot be overridden (no software).
With that, nothing is going to stop a determined and opportunists type thief from gaining entry into any vehicle, i.e. breaking glass, that's a given, but that's a different subject than being able to drive away with it. And, If an experienced and trained Ravelo installer were to ever start ripping off vehicles, I'm sure like other thieves, he'd choose the ones that don't already have a Ravelco installed.
Nothing. But here again we get into a continuous "what if" scenario. You can do that for any device made for any application. Really serves no purpose in the end because there's a way to defeat most anything.
Had a simple but effective on my 99 7.3. Interrupted the brake pedal switch under the dash. (Automatic transmission)
Could start the truck but if the switch was on, no way your getting into gear.
I have a Ravelco. The fob attachment is tastefully hidden out of sight so it would be hard to imagine anyone complaining about the aesthetics.
Quality installation is mandatory. My installer took about 4 hours to do it with meticulous work. I doubt the folks at my Ford service department would be able to tell with a careful look under the hood. And the same guys who installed it could take it down if I ever wanted that (I won’t). If I were to ever sell it I’m sure the buyer would appreciate it. I have a lot of aftermarket stuff on the ride, so this was a no brainer. I also have Viper + SmartStart ever since Ford d/c SmartLink. Nice battery-backup Bluetooth siren as a backup to the factory horn alarm. If I only could have one - Ravelco.
Performance has been flawless. I love the peace of mind. I doubt you could get this type of installation quality with a homemade kill switch of any kind.
The main problem I see with this is if you ever have a problem with a no start concern you could be in for some hefty diagnosis charges. Regardless of the quality of the product, things fail sometimes. If you take it to Ford and their technician spends an hour or so tracing the problem to the Ravelco product warranty will not cover that. You also run the risk of Ford and Ravelco pointing the finger at each other claiming their product isn't the cause of failure. With all the mods you have there is a good chance you will run into a warranty problem should you have any type electronic failure, if your vehicle is still under warranty that is.
I appreciate your concern. Back to the OP and the the main topic: I think it is pretty reasonable to expect that a professionally installed system that has been used for years as a kill switch is a lot less likely to have any issues vs a homemade solution, hence my recommendation. I have had Ravelco in various vehicles over 20 years without any issue. I think your concerns, though hypothetically possible, are fairly irrelevant if the OP already wants to install a kill switch. The OP is weighing value vs cost. That is a legit consideration. I went Ravelco (higher cost) because I’m not comfortable doing it myself, and I’m much much more confident in a proven product to virtually eliminate the concerns you suggest.
