460 engine stumbling under load
Old Nov 10, 2019 | 04:24 PM
Maillemaker's Avatar
Maillemaker
Hi all,
My RV is a 1990 E350 with 460 EFI engine.
Recently it has begun stumbling under load. Seems to run fine at idle, and if you are sitting in park you can rev the engine without issue.
Things already replaced:
Fuel Pressure Regulator (30 PSI at idle - 38 PSI under load) I have installed a digital fuel pressure gauge off the fuel rail so I can monitor while driving. No change in pressure when stumbling.
Fuel filter
EGR Valve
EGR Valve Position Sensor
EGR Valve Solenoid
Coil
Spark Plugs
Spark Plug wires
Distributor
Ignition Control Module
Engine Temperature Sensor
Catalytic Converter
In-tank fuel pump (about 4 years ago).
Idle Air Valve
The computer is throwing no codes - get an 11 for both Key On Engine Off and Key On Engine On tests using ODB1 reader.
Any ideas?
Old Nov 10, 2019 | 07:07 PM
jeffreyclay's Avatar
jeffreyclay
not sure since you've already replaced them but my first feeling was plug wires.
Old Nov 11, 2019 | 04:47 PM
Spaznaut's Avatar
Spaznaut
30 seems low for idle. I think mine is around 40-50. If your not pulling a lean code then I'm not sure what's going on unless it's a timing issue. You may have a timing chain with quite a bit of slack. You may also need to check your injectors.
Old Nov 11, 2019 | 06:40 PM
Maillemaker
I recently replaced the fuel pressure regulator. Wasn't having problems before then.
https://www.ford-trucks.com/forums/1...gulator-2.html
With original FPR, I was getting 41 PSI key on, 38 PSI idle, 48 PSI with vacuum removed.
With the new FPR, I'm getting 36 PSI key on, 30 PSI idle, 39 PSI with vacuum removed.
The OEM FR engineering ID was E7DE 9C968-BA.
The replacement was F4CE-9C968-AA.
Maybe I put the wrong Fuel Pressure Regulator in?
I bought it from Rock Auto. This is what they said should go in my vehicle.
The engine has about 87K miles on it - too young for a stretched timing chain I would think?
I did consider the injectors. When I replaced the fuel filter, it looked horrible.
Steve
Old Nov 11, 2019 | 09:19 PM
Spaznaut's Avatar
Spaznaut
Yeah the modern ethanol gas is horrible when it sets for awhile like on motorhomes. Do you have your original regulator? You may wanna stop by your local NAPA and see what they pull up for the replacement. They are 'sometimes' knowledgeable on which part you need.
https://www.napaonline.com/en/search...=nol-veh-conds
Old Nov 12, 2019 | 05:27 AM
JWA's Avatar
JWA
With all the conversation about a FPR etc possibly being the wrong part I'd shy away from RockAuto, NAPA or any other outfit opting instead to get the original part through a dealer based upon the VIN. Some automatically think dealership's charge double or triple what the aftermarket suppliers change but a bit of shopping for the correct part number often yields great results, major cost savings IOW.
Of course all this depends whether the correct part number is known.
Old Nov 12, 2019 | 08:05 AM
Maillemaker
Yes I know the correct number is:
CM-4646 Service
Service #: E6AZ 9C968-A
Engineering #: E7DE-9C968-BA
https://www.rockauto.com/en/moreinfo...=46991&jsn=530
I have ordered this one and will replace and see if there is a difference in PSI and performance.
Old Nov 15, 2019 | 07:59 PM
Maillemaker
Well, I replaced the fuel pressure regulator twice tonight. One to put in CM-4646. It generated pressures almost identical to CM-4764. Then I re-installed the OEM regulator that came with the vehicle. It generates pressures a good 10 PSI higher than the two new replacements.
And I still have my stumbling problem.
So, my stumbling problem is not a result of replacing the fuel pressure regulator.
I'm back to square one.
Old Nov 16, 2019 | 02:10 PM
Maillemaker
We can now also rule out the HEGO Oxygen Sensor. Replaced it - still stumbles.
Steve
Old Nov 21, 2019 | 09:10 PM
Maillemaker
I saw this guy's video on YouTube. It was his video on the Fuel Pressure Regulator that enticed me to replace mine:
But he had a follow-up that I just found today where he said the FPR did not fix his problem, and replacing the MAP sensor did:
So tonight I replaced the MAP sensor. It is very easy to get at - it's mounted on the lip of the rear flange of the engine opening, above the blower motor.
Took it on a test drive. I go in a loop - about 15 minutes of 60 MPH, followed by about 20 minutes of interstate, followed by about 15 minutes of surface streets.
At first I had it licked. While the engine was cold, it did not stumble any that I could detect. But after running on the interstate and then merging onto the next stretch of interstate, it was bucking and popping and backfiring.
At interstate speed it runs fine.
I was down to less than a quarter tank of gas. I put in 2 bottles of GumOut Fuel Injector Cleaner. Went for another circuit. Had some more stumbles. Stopped at Costco and put in a full tank of their Top Tier detergent gasoline (I usually use Mapco which is not Top Tier gas).
Went home - had a few more minor stumbles but nothing major - all surface streets.
Got home, sat in the driveway and revved the engine a few times - blew a heater hose. Nice ending to the evening.
Starting to think my dad is right - best fix for this RV is a stick of dynamite!
Steve
Old Nov 21, 2019 | 10:13 PM
Steve460's Avatar
Steve460
Replacement ECU or original
Old Nov 21, 2019 | 10:18 PM
Maillemaker
Still original ECM. I picked up the second replacement today. I'm gunshy of opening the box given how crappy the first one was - hoping I can return this one for a full refund since the seal is not yet broken.
Steve
Old Nov 22, 2019 | 06:19 AM
Steve460's Avatar
Steve460
Give it a try, if it doesn't resolve your issue but runs no worse then return it for a refund 😁
Old Nov 22, 2019 | 08:17 AM
Maillemaker
Well, the problem is once you open the box you can only return it for core credit ($70).
I'd hate to install the new computer and find it runs like crap again like the first computer did and only be able to return it for core.
But this weekend I'm replacing the last of the engine sensors - the Throttle Position Sensor and the Air Charge Temperature Sensor.
About the only other sensor on the vehicle that may be engine-related that I have not replaced is the Speed Sensor in the transmission.
I'm also going to build a "smoke can" this weekend that vaporizes mineral oil (baby oil) and pump it into my intake manifold to see if there is a hidden vacuum leak somewhere.
If I have time and that doesn't get it I'm going to pull the injectors and flush them out and replace their o-rings.
Last resort I'll pop in the new computer.
Steve
Old Nov 23, 2019 | 12:23 PM
Maillemaker
FIXED!
So, this morning I replaced the Air Charge Temperature Sensor, and voila, the problem is fixed!
In hindsight, I probably should have suspected this sensor earlier. About 6 months ago the engine was having difficulty idling when cold. When I had it in the shop to have the Distributor replaced, I told them this, and they replaced the Idle Air Control Valve. It did not help. Since it only idled poorly when cold, I suspected a temperature-related issue, so I replaced the Engine Temperature Sensor. It immediately fixed the cold idle problem.
It turns out, the Engine Temperature Sensor and the Air Charge Temperature Sensor are essentially the same sensor and sensor body, but on the ACTS they have machined away the brass nipple end of the sensor body to expose the actual sensing element to the air to improve response time.
I suspect that I cooked both these sensors with the extended overheat condition I had back in 2016. If one sensor got cooked, it should not be surprising that the other sensor got cooked also.
Of course it is obvious how primitive the ODB1 EEC-IV computer system is that it is unable to detect faults in these critical engine management sensors. In both cases, no code was thrown due to a faulty sensor.
For anyone in the future who might stumble across this thread, I'll admit that my approach to fixing the problem - sequential random replacing of various engine sensors - is not the smartest or most cost-effective way to do diagnosis. The proper way is to identify the sensors that might be relevant and test them. Most sensors can be tested by some procedure that can be discovered in a shop manual or online.
I did not mind the "throw parts at it" approach so much for a few reasons. First of all, at the time of this writing the vehicle is 29 years old. Since I have already had sensor component failures, I don't mind replacing sensors that are 30 years old. I do worry a bit about replacing possibly good OEM components with aftermarket components that might not last as long, but after all, this is an RV, so it's not going to see that many miles in the years ahead anyway. It only has 86K right now, so it's averaged 3,000 miles a year over the last 29 years.
The second reason I don't mind my approach is that most of the sensors are relatively cheap. I suspect for all the sensors I've replace so far I'm in for less than $300. And the labor to get at the things to test them is about the same as to get at them to replace them, so if I'm going to go to the trouble, I may as well just replace the thing rather than figure out how to test it.
The final reason goes hand in hand with the second reason, and that is that I live in a subidvision with an HOA, and I can't leave my RV in the driveway for more than 24 hours. So time is of the essence when I start pulling things apart. It's quicker if I'm going to pull the sensor for testing anyway to just pull and replace.
So, until the next thing breaks, see you 'round the 'net!
Steve
