Need help.
Old Nov 9, 2019 | 11:55 PM
James Golden's Avatar
James Golden
Need help.
I’ve got a 1996 Ford F-250 with a 5.8L 351. It is a five speed. It’s not getting any fuel nor spark. I’ve replaced the fuel pump relays but the fuel pumps won’t kick on when I turn the key over. Replaced the computer. The ignition module. The ignition coil. Spark plugs. Wires. Mass air flow sensor. Distributor is new. I heard it could be the pick up coil in the ignition. Let me know what you guys think. Thanks in advance!!
Old Nov 16, 2019 | 11:14 AM
rla2005's Avatar
rla2005
There is an inertia switch located behind the passenger side kick panel. It has been know to trip off on it's own. That will prevent power from passing through to the selected fuel tank/pump. But that will not prevent you from getting spark. Does the Check Engine Light come on when you cycle the key from the Off to Run position?
Desireg
Sep 25, 2015 05:22 PM
firedawgs
Jul 28, 2014 10:22 PM
Peter15
Aug 20, 2012 07:38 PM
95 F150 Dude
13
Nov 16, 2009 02:20 PM
BRX98GT
1983 - 2012 Ranger & B-Series
Sep 10, 2004 08:38 PM
