Ignition trouble
Old Aug 16, 2012 | 07:07 PM
Peter15's Avatar
Peter15
Ignition trouble
I have a 1992 F150 5.0L automatic transmission pickup.* I have been having trouble getting it to start.* It began with it taking a longer and longer time to crank before it would start up.* Now, it won’t start up at all.* It cranks and cranks and cranks but won’t ignite.* There are 200,000 miles on the engine.* I replaced the fuel filter roughly 3,000 miles ago.* The fuel pump relay switch was replaced roughly 200 miles ago.* The spark plugs were changed out roughly 1,000 miles ago.* This morning, I replaced the distributor cap, rotor, and put a new ignition coil in it.* Still just cranks and cranks and cranks, no ignition.* It is a dual tank for the gas, and I have tried both tanks, so unless both pumps went out simultaneously, I don’t think that is the problem.
Old Aug 16, 2012 | 07:42 PM
burnout400m's Avatar
burnout400m
Did you pull the codes? Did you pull a spark plug and ground it to see if you had spark? did you check fuel pressure? Are the plug wires new too? There's also an ignition control modal. Mine is inside the DS fender near the firewall.
Old Aug 16, 2012 | 08:14 PM
subford's Avatar
subford
Does the selected fuel pump run for one second and quite each time the key is turned on?
If no then ground pin #6 of the self-test plug and turn on the key. Does the selected fuel pump run for one second and quite each time the key is turned on now?
If the fuel pumps run OK with just the key then check for spark, if you do not get any spark unplug the computer and see if spark returns.
If it does you either have bad grounds (40 & 60) and lack of power (1, 37 & 57) to the computer or you have a bad computer.
If you still do not have spark with the computer unplugged then you have either no power to the coil/ICM, bad ICM or a bad PIP sensor.
Old Aug 20, 2012 | 07:38 PM
Peter15's Avatar
Peter15
No spark. Bad grounding to the ignition coil. Wire harness needs replacing
HoosierDaddy1
Jun 12, 2017 10:51 AM
Desireg
Sep 25, 2015 05:22 PM
Royson12
Jul 30, 2015 04:28 PM
cabloom300
Feb 12, 2014 10:16 PM
dmcf150
Feb 13, 2011 05:35 PM
