My 95 4.9 E40D just plain quit without warning on the expressway yesterday. I was running about 70, 3/4 tank of gas, no check engine lights, normal tempature, no noises...it just quit. It will turn over and I hear the fuel pump energizing but it won't fire. I tried switching tanks but it still made no difference. Where do I start?
any engine needs 3 things to run, compression, fuel, and spark. You will need to see if you have proper fuel pressure and that you have spark at the plugs. My first guess would be an ignition module.
Scott
When you say you can hear the fuel pump energizing what do you mean?
Do you mean you can hear the fuel pump run for one second and quit when you turn on the key or do you mean you can hear it run all the time the key is on with the engine not running?
If it is the second part of the question then I would say you lost the PCM Computer.
If it is the first part of the question then I would say you have a bad PIP sensor in the distributor.
May not be either one but the above would be your best bets.
Does it fire after sitting for a while? If so, check the ignition coil- it's typical for an engine to just quit and then fire up after it's set for a while if the coil is going bad.
Thanks for the responses Yes, I do hear the fuel pump energize and continue to run.
No, the engine will not run after it cools, it will crank but won't start.
I did pull the cap and rotor off to look for moisture or other signs of trouble but nothing was obvious. What does the PIP look like and how do I get to it?
Then I would say you have a bad Computer.
To get to the PIP you have to pull the distributor out and completely take it apart.
But you do not have to worry about the Ignition system if the fuel pumps run all the time the key is on with the engine not running.
air, fuel and spark are the three things needed for an engine to run.
an engine with bad compression will still run.
True but it depends on how bad the compression is and how many cylinders have it. I believe 90 PSI is the minimum needed- I'm sure that can vary by a few PSI and still be okay, but basically anything lower than that is a dead cylinder.
Do a compression check anyway- it won't hurt. And have you tried checking spark strength? If there's a weak spark the problem is likely still in the ignition circuit.
To comment on what you guys said about the compression, I've got a 302 ( sorry 5.0, still not used to these sillyliter thingies. Too old to learn new stuff ). Any way I was just told 2 cyls. next to each other only have about 70 lbs. The instructor at Tech. School says that's the minimum for it to fire. Being a V-8, I never noticed it. The little bit I drove it before putting in the shop, it ran great ( I thought ). Plus the timing was off by about 5°. If & whenever I ever get the head gaskets done, it should run like a violated ape.
i have bought and driven home a car with a v8 and 2 dead cylinders.
did not run well but it did run.
drove it from l.a. to san diego on the interstate.
you have mentioned the three things you think you need to have an engine run before and i am just trying to clear things up for you.
Well, 8 cylinders minus 2 would mean 6 cylinders were still operational. Like you said it didn't run well but it still ran- which is why I said it depends on how many cylinders have bad compression. If you have a V8 with only 2 operational cylinders, chances are good it's not going to run. A 4 banger, on the other hand, might be a different story.
I wasn't trying to say that you were completely wrong, and I'm not trying to start an argument here- just making the point that bad compression can and does keep an engine from running depending on how bad it is.
Apologize if anybody thought I was saying they were wrong, was just trying to list what me experience was with the compression issue. For what it's worth, just got a new message from him & now he tells me the entire left side is only showing about 60 - 65 lbs. I'm starting to get that feeling. Still say it was running great before I took it in to them.
