periodic spark
Old Jul 28, 2014 | 02:57 PM
firedawgs's Avatar
firedawgs
periodic spark
Fuel pump died on my 1996 f250 after new one was installed truck wouldn't start I have fuel pressure but no spark. Replaced ICM, and ignition coil got spark but after I drove the truck about 50ft it died.could I have a issue with the wiring in the tank or fuel system safety that's causing this
Old Jul 28, 2014 | 10:09 PM
Ford_Six's Avatar
Ford_Six
Moved from the Garage and Workshop forum, this thread should get a whole lot more exposure here.
Old Jul 28, 2014 | 10:22 PM
JKNW's Avatar
JKNW
Your fuel pump has nothing to do with your ignition, so no it's not anything in your fuel tank causing you to lose spark. If you've got a new ignition module and your ignition switch is good, and your secondary ignition parts (rotor/cap/plugs/wires) are good the distributor is about the only thing left to go bad.
Desireg
Sep 25, 2015 05:22 PM
areoseek
Mar 20, 2014 02:18 PM
Peter15
Aug 20, 2012 07:38 PM
1991ford_trucker
23
Jan 24, 2011 06:34 PM
projectnitemare
Feb 12, 2006 08:17 PM
