Brake question
Old Nov 5, 2019 | 09:29 PM
Ace Alford's Avatar
Ace Alford
Brake question
Howdy folks--I could use some expert advice. I'm good with woodworking, but not so much with mechanics. But, being newly retired with more time than money I'm trying to do a bit more "fix it myself". My truck is a 2002 F250 with 7.3 turbo diesel and is a great, strong old truck. My issue is brakes. Pads and rotors good, but pedal will go to the floor. If this was an old 50's model truck like I used to have it would surely be a "bleed the brakes" and fix. The issue is I'm not losing any brake fluid and I can find no leak anywhere (including around the ABS unit). You can pump the brakes and kinda make do for a bit and then you are pumping again. My hope is you can direct me toward some things to try to identify the issue in a bit more efficient manner than just start buying components and hoping for the best (which is unfortunately the method used by the last couple of local mechanics I've used).
Code does show the long and typical list that begins with ABS relay and then lists more expensive possibilities (including new ABS pump, etc.). I greatly appreciate any suggestions anyone might make before I start trial/error methods.
Thank you.
Old Nov 5, 2019 | 09:52 PM
Walleye Hunter's Avatar
Walleye Hunter
Did you delete your codes and see what comes back up? Your master cylinder would cause your symptoms if it's going bad.
Old Nov 5, 2019 | 09:55 PM
woodnthings's Avatar
woodnthings
How is the steering on your truck? The hydroboost system is part of the steering pump and can cause the brake pedal to go to the floor. As mentioned above, the master cylinder can be the cause.
Here is a link to the tech folder and there are great write-ups in there. https://www.ford-trucks.com/forums/1...-7-3l-psd.html
Old Nov 5, 2019 | 10:16 PM
Ace Alford's Avatar
Ace Alford
No sir, I did not delete to check again but I will. Thank you.
Old Nov 5, 2019 | 10:17 PM
Ace Alford's Avatar
Ace Alford
No problem with the steering and thank you for the link. I'll read it over.
Old Nov 5, 2019 | 11:08 PM
Wes444's Avatar
Wes444
Have you flushed the power steering/hydroboost system with new ATF? Takes about 3 qts
Old Nov 6, 2019 | 08:52 AM
Brother Les's Avatar
Brother Les
Yes, you read that right. Automatic Transmission Fluid....
Do not put 'Power Steering Fluid' in the 'Power Steering Pump..... ATF ONLY
Old Nov 12, 2019 | 09:45 AM
Josh Ross's Avatar
Josh Ross
Diverdude
X2 on flush
Like mentioned above, flush the hydro boost and ps.
Old Nov 12, 2019 | 11:54 AM
Brother Les
7.3 power steering flush.
rowekmr
Jun 10, 2019 12:25 AM
largefries
Sep 29, 2010 12:37 AM
ramblin' guy
Oct 26, 2008 10:34 AM
tuke
Sep 15, 2007 02:00 PM
gt5-33
1997 - 2003 F150
Apr 23, 2007 09:19 AM
