Bleeding brake procedure?
you will need an extra hand to do this also. do not bother using the vacuum pump brake bleeding kit. they do not work.
break the bleeder loose, then tighten it back up.
have extra hand get in the truck and pump the brakes until they are hard, then pump it again and keep pressure on the brake pedal.
pop a clear tube onto the bleeder and into a jar partially filled with new fluid.
submerge the end of the line in the fluid.
tell extra hand that the pedal WILL drop to the floor and once it does tell them to keep pushing on the pedal and to NOT release the pressure.
loosen the bleeder until you see fluid coming out.
ask extra hand if the pedal has reached the floor. (it happens really fast so there's really no point on asking if it did or not...lol)
tighten up the bleeder.
have extra hand pump up the brakes again and repeat.
repeat the bleeding procedure until you get nothing but straight fluid from the bleeder with NO air bubbles.
keep on top of the master cylinder as you will need to keep topping it up with new fluid as you do this.
switch to other side. and repeat.
have the same '89 F150 sauper cab with ABS brakes .
Truck sat for 8 yrs since l parked with blown engine .
Now with everything all new and brake system totaly seased up l have replaced brake lines and all wheel cylinders and calipers and the mastercylinder du to they where all frozen .
What will l have to do bleeding and to get the ABS up and going ?
Thanks from Ripspeed .
