No start when hot
Old Nov 2, 2019 | 12:44 PM
Blessings's Avatar
Blessings
No start when hot
Hello can someone help please!!! I have a 05 F250 with 6.0 powerstroke engine.When cold the engine start and run fine but once hot and i stop the engine i cannot start it anymore until it get cold.This started after i changed an injector on the passenger side.I have checked the injectors no leak,Changed stand pipe and dummy plug with the upgrade ones still no start when hot.On IDS when engine is hot and before i stop it in order to restart IPR shows 84.76% ICP volt-0.9, ICP prs-502psi.
Can someone please tell me what to do.Thanks
Old Nov 2, 2019 | 01:00 PM
AL`'s Avatar
AL`
Perhaps this: STarts when oil cold, wont when warm?
Old Nov 2, 2019 | 01:14 PM
Blessings's Avatar
Blessings
Yes AL that is it.This is how it started.I changed an injector on the passenger side when finished i started the engine it was ok but when i stopped it and wanted to start itagain it result in a no start.The next day morning the engine started fine but when it warmed up and i stoped it in order to start again it result to a no start.
Old Nov 2, 2019 | 01:16 PM
AL`'s Avatar
AL`
Here's another link from the tech folder: Troubleshooting a No-Start condition
Old Nov 2, 2019 | 01:35 PM
bismic's Avatar
bismic
Has your HPOP's STC fitting been updated?
Old Nov 2, 2019 | 01:37 PM
Blessings's Avatar
Blessings
No i have not yet updated it.But does it get bad so sudden?
Old Nov 2, 2019 | 01:50 PM
bismic's Avatar
bismic
Like any oil leak - it can start to leak suddenly or it can be a slowly progressive thing.
An air test of the high pressure oil system is the proper response to a hot no-start. Since you have done the standpipes and dummy plugs, the STC fitting is the next most likely issue ... but do the air test.
Old Nov 2, 2019 | 02:05 PM
Blessings's Avatar
Blessings
Thanks bismic but how to do a proper air test?
Old Nov 2, 2019 | 02:09 PM
bismic's Avatar
bismic
IMO the best way is to buy the fitting that installs in place of the IPR valve. That takes a bad IPR valve out of the equation and it gives you an opportunity to inspect the IPR valve before doing any more work.
All that stuff can be found in the Tech Folder thread on troubleshooting a no-start condition.
DieselTechRon has great videos on air testing and hot no-start troubleshooting. Links to those videos are in the thread.
Old Nov 2, 2019 | 07:18 PM
SmackDaddy's Avatar
SmackDaddy
Get the IPR port air test fitting for about $25 online. No need for a high quality $100 piece just to put 150psi on it.
Old Nov 2, 2019 | 10:16 PM
Fuzzpuss's Avatar
Fuzzpuss
What is your oil temp when it dies?
Old Nov 3, 2019 | 10:31 AM
Blessings's Avatar
Blessings
When I start the engine i bring it to the normal working temperature before stoping it in order to try starting it again
Old Nov 3, 2019 | 10:42 AM
Fuzzpuss's Avatar
Fuzzpuss
The reason I asked is that I had a "stalling and hard start when hot" that turned out to be a plugged oil cooler. The oil was getting so hot it had lost its viscosity and the pump couldn't build or maintain pressure. It would help to know how hot it is at the point the truck doesn't start, as in an actual temp reading, not what the factory gauge shows.
Old Nov 3, 2019 | 12:06 PM
jdw1's Avatar
jdw1
I’m suspicious of a bad STC.
jmo
How many miles on the trk?
02GrayPowerStroke
1997 - 2003 F150
Aug 19, 2019 01:16 PM
spanky350
Feb 17, 2016 04:18 PM
corbin68
May 11, 2011 02:35 PM
Trucky2
Sep 23, 2010 06:33 PM
j-bar
May 1, 2010 08:33 AM
