66 Tail Light Wiring
Old Oct 30, 2019 | 04:41 PM
TA455HO's Avatar
TA455HO
Lead Gopher
If you have an NP435 you could keep an eye out for a newer shift tower from a 1967 or later NP435
https://www.ebay.com/itm/1973-79-For...gAAOSwum9c-npo
If you look at the pics of this one on eBay you might see the red connector on the drivers side of the tower. That was what they used to provide the ground path for the backup lights when you shift to reverse. Simple swap if you find one reasonably priced.
Old Oct 30, 2019 | 05:30 PM
lewiscrouse's Avatar
lewiscrouse
Unfortunately I've got the T-18. I'll have to do some research to see what else they put these in and if there's a swap I could do.
Old Oct 31, 2019 | 01:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Crop Duster
The PO had already installed one of these on my truck. It was in poor condition so I ordered a new one from LMC with a new gasket. I was pleasantly surprised when it turned out to be equal in quality to the original Ford part. The only difference the glass lens says LMC on it instead of FORD. I have a C6 trans so it was easy to wire it into the circuit but I did add a switch so it could be turned on at any time. It is bright enough to give a little help backing up. https://www.lmctruck.com/1957-72-for...amp-components
^ This is the optional cargo lamp used on 1967/79 F100/350. It's the same as 1964/65 Thunderbird backup lamp.
T-Birds have two of these, right/left is the same, located below the tail lamps on the valance panel.
alvald83
Jul 24, 2019 07:42 AM
Mason_72_F100
Jun 18, 2019 08:03 AM
bphirt1
Feb 26, 2015 09:22 AM
Myfreeford
Nov 30, 2010 06:02 PM
74crewcabshortbed
Jul 25, 2007 08:42 PM
