Hydra Tunner w/Shift kit
Old Oct 28, 2019 | 01:37 PM
1leg's Avatar
1leg
So I ordered a Hydra over the weekend from Riffraff. I found out that the trans was built with "Tugger" shift kit I suspect that when I pulled the unknown 6 position tuner out that it is the reason for my slowish shift points. I'm hoping the Hydra will improve the shift points. The trans shifts great when driving around town during most accelation situation but under any load it just seems to take longer then it should for the 1-2. looking for advice on what tunes to load for a basicly stock set-up DD and tow pig.
Old Oct 28, 2019 | 01:46 PM
akcooper9's Avatar
akcooper9
You will want to use the VB tunes.
Old Oct 28, 2019 | 01:53 PM
HKusp's Avatar
HKusp
Yeah, whatever tunes you pick, the tunes should be calibrated with a valvebody in mind.
Old Oct 30, 2019 | 09:34 PM
1leg's Avatar
1leg
Hydra install! Holy Crap
I installed the Hydra tuner tonight after work. Only had time to install 6 tunes and only got to do a quick test drive around the block. But holy crap what a difference. I installed the stock tune, 65 hp sipper, 65 Sipper w/modified VB, 80 hp DD, and 80 DD w/modified VB. I was thinking I could to some A/B testing between with and without VB tune tomorrow on my way home from work.
I didn't even get to the 80 hp tune, But I can tell you right now the 65 hp w/modified VB tune fixed my transmission shifting issue. With the 65 hp it feel as powerful as my 2004 Dodge TDS dually. I think I wold be happy with a 30 hp sipper w/modified VB.
What is the difference other the HP between the Sipper, DD and Tow tunes?
Old Nov 1, 2019 | 01:08 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
No idea on the Hydra tunes, but definitely sort it out further. Drive a day in each tune to really get a feel for it before trying another.
You have a regular commute so back to back days are a valid test?
Old Nov 1, 2019 | 08:32 AM
Jo7.3's Avatar
Jo7.3
The shift points are the biggest difference between the sipper, DD, and tow tunes.
Sipper will shift through the gears the quickest.
DD tunes will also be quicker than stock in terms of shifting, but not as quick as fuel sipper.
Tow tunes will hold each gear longer than stock, sipper, or the daily tunes.
Old Nov 1, 2019 | 10:22 AM
1leg's Avatar
1leg
Thanks for the replys, I could feel and see on the tach that the W/Modified Valve body tunes made a difference. I have reload the tunes and only installed the tunes with modified valve body. I drove for the first time the 40hp DD and I think that is enough for me as far as HP and it shifts better then the stock tune.
Current tune list installed.
01 - Server File: VRAA6S3: 0 HP - Factory Stock
02 - Server File: VRAA6S3: 40 HP - Daily Driver w/Modified Valve Body
03 - Server File: VRAA6S3: 65 HP - Fuel Sipper w/Modified Valve Body
04 - Server File: VRAA6N3: 80 HP - Daily Driver w/Modified Valve Body
05 - Server File: VRAA6S3: 0 HP - 1000 RPM High Idle w/Modified Valve Body
06 - Server File: VRAA6S3: 25 HP - Towing w/Modified Valve Body
07 - Server File: VRAA6S3: 40 HP - Towing w/Modified Valve Body
08 - Server File: VRAA6S3: 65 HP - Towing w/Modified Valve Body
09 - Server File: VRAA6S3: 80 HP - Towing w/Modified Valve Body
10 - Server File: VRAA6S3: 0 HP - 1200 RPM High Idle w/Modified Valve Body
11 - Server File: VRAA6S3: 0 HP - Whisper Mode w/Modified Valve Body
Old Nov 1, 2019 | 08:06 PM
00t444e's Avatar
00t444e
Quit messing around and load the 140 tune.
Old Nov 1, 2019 | 08:34 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Wrong...
He should continue experimenting until he finds a tune suitable for each of his driving scenarios. Then, remove the unused tunes and be happy that his truck is performing exactly the way he wants.
Old Nov 2, 2019 | 05:49 PM
1leg's Avatar
1leg
Originally Posted by Sous
Wrong...
I'm not going anywhere near the 100+HP tunes I want to put another 200,000 on this motor. I really like the power of the 40 hp DD, But the 65 hp sipper just shifts so much better. I would really love a 40 hp sipper tune. It would be perfect for my DD style. The towing tunes will just have to wait until I get some weight behind this thing. I really like the hi idle mode, I don't do it in the morning but in the afternoon after starting the engine to leave work I bump it to the 1000 rpm for a couple of minutes to warm the motor up.
Old Nov 3, 2019 | 10:09 AM
Jo7.3's Avatar
Jo7.3
I'd rather have stock power with perfect shifts than a hot tune with horrible shifts.
I really liked the Hydra canned tunes except for one issue: the torque converter doesn't lock up in 3rd gear. I do have a fully built trans by my local trans builder, so I'm guessing that could be my issue. When I get some free time, I might go to my trans builder and see what he can do. But for now, I'm happy with the custom tunes I'm running.
dozer384
Mar 31, 2005 09:28 PM
akbash
Computer Chips & Tuners
Dec 13, 2004 07:28 PM
BagStroke
Apr 23, 2004 07:42 AM
Bucky
Mar 19, 2004 12:58 PM
02'bluemule
Apr 3, 2003 07:56 AM
