Cab Body Work Question
Old Oct 30, 2019 | 09:29 AM
CharlieLed's Avatar
CharlieLed
Originally Posted by clintonvillian
Charlie,
I had my first experience last night with the panelbond. It went pretty well, it was bit messy with the 1/4" tube on the hood though. It would be much easier doing an overlapping panel.
The panel bond was sticky, I used my gloved finger to smooth it down. Is there any advantage (besides cost) to using the heavy bodied seam sealer over the panel bond?
You will find that, just like when painting, a little masking tape goes a long way towards keeping the adhesive off the areas that are not intended to be bonded. If you wet your finger before you smooth over the adhesive then your finger will not stick and the surface will be smoother. Panel bond is stronger than seam sealer. Panel bond takes longer to cure than seam sealer. Panel bond will flow out as it cures resulting in a high gloss finish...will also drip if not contained. Panel bond is harder when cured. I personally have never used seam sealer to bond panels, that said, I would think that in this application it should work just fine.
Old Oct 30, 2019 | 11:29 AM
clintonvillian's Avatar
clintonvillian
I didn't explain that very well....
I'm considering using panel bond in lieu of seam sealer on the rest of the truck. My only concern was that it may not be flexible enough...
Old Oct 30, 2019 | 10:51 PM
EBEAR's Avatar
EBEAR
I would stick with seam sealer . Panel bond is not designed to be thick and any that I have used is far too runny to stay in place .
old22fan
Oct 22, 2019 07:08 AM
grandaddy's52
Oct 19, 2019 02:46 PM
foofees
Apr 22, 2017 01:22 PM
create
May 25, 2008 08:57 PM
fords_forlife
Paint & Bodywork
Jul 30, 2005 11:17 AM
