Sponsored by: Real Truck
Collar on Drive Shaft?
Old Oct 22, 2019 | 11:19 PM
Shadoza's Avatar
Shadoza
8th Gear
Hey guys. I got a pure stock AFAIK 2001 F-250 7.3 liter. I have had it for about 6 years now. This morning a piece of rubber came off my driveshaft while I was leaving for work. I have no idea what it is or how to explain it. I did, however, make a video about it. Can you tell me what this is and what it is for and why I need it?
Old Oct 22, 2019 | 11:41 PM
85e150's Avatar
85e150
It's a drive shaft harmonic "balancer" or damper.
Confounding people for years:
https://www.ford-trucks.com/forums/8...-balancer.html
IMO have it replaced. You will never notice the vibrations it dampens until they take out a pinion bearing. Or maybe you will when you notice your mirrors are fuzzy at certain speeds.
Meanwhile I'd see if I could get that ring off there until proper reinstallation can be done.
Old Oct 22, 2019 | 11:55 PM
Shadoza's Avatar
Shadoza
8th Gear
Oh wow. Thanks. I've never heard of such a thing. I am glad that happened under 15 MPH! Now I am going to cuss my truck for a bit and figure out how much money this is going to cost.
Old Oct 23, 2019 | 12:21 AM
Shadoza's Avatar
Shadoza
8th Gear
Actually. Is there a way I can glue this all back together? It seems like adhesive or pressure was the only thing holding it on to begin with. Is the ring offset to compensate for variations in the driveshaft weight? Would the driveshaft be balanced according to the variations in the ring's weight? How exactly does this function?
Old Oct 23, 2019 | 08:50 AM
DesertSmoker's Avatar
DesertSmoker
Remove it and have your drive shaft re-balanced. Depending on your mileage you may want to consider u-joints and a new center support bearing.
Old Oct 23, 2019 | 05:02 PM
85e150's Avatar
85e150
While it was in fact held together by some combination of pressure and friction, you can not glue it back together. It will come apart in short order.
You can have your driveshaft balanced all you want, and that's a good thing. This damper is not primarily for driveshaft balance. It is for harmonic vibrations. Those torsional impulses from the engine that find their way through the drivetrain. And other vibrations that in harmony with the frequencies in your driveshaft can mount up to create larger vibrations.
Harmonic--think harmony. A great thing for the choir, not so good when it's different components finding a common frequency to buzz to.
Old Oct 23, 2019 | 05:21 PM
Shadoza's Avatar
Shadoza
8th Gear
Harmonic--thing harmony. A great thing for the choir, not so good when it's different components finding a common frequency to buzz to.
I believe you. The fact that not many people have much knowledge on this is amazing to me. I Googled drive shaft repair and called the first result. That guy didn't know what I was talking about then admitted they took their drivelines somewhere else for repair and they only R n R. So I called that place then drove my truck there. Luckily it was only a couple blocks from my house. The guy kept trying to tell me it was the carrier bearing until he crawled under my truck, then he didn't know. He called someone and that someone didn't know. Now the drive line repair shop has informed me that I should just cut it off myself or they can do it for a small fee.
I understand it is on there for a reason and I really want to keep my truck for another 800k miles and get to a million. I am going to cut it off so I can at least drive it and start setting aside for a new drive line next month. I guess my truck gets the most expensive gift this Christmas.
Old Oct 23, 2019 | 06:52 PM
85e150's Avatar
85e150
Yes, cut it off and inspect the shaft for any dents or dings however small around where it has been clanking away.
You can run without it, and you may never notice it. "May". For the 800k run, it probably should be replaced.
Funny you ran into "shops" that do driveline repair and they've never dealt with one before. They are a "thing" with Jeep, Dodge and Cummins forums, and that was the first page.
Good luck!
Old Oct 23, 2019 | 07:20 PM
Shadoza's Avatar
Shadoza
8th Gear
Good luck!
Thanks so much for your help. If there was a way for me to buy you a cup of coffee I'd be happy to. I will keep you posted on the results.
Old Oct 24, 2019 | 09:37 AM
Shadoza's Avatar
Shadoza
8th Gear
Cut it off last night. No vibrations. Thanks everyone for your help.
IBleedOvalBlue
Jun 11, 2011 12:31 AM
995.4SD
Mar 1, 2010 12:44 PM
Mudflappus
Dec 12, 2005 05:57 PM
