2011 - 2019 Explorer Discuss the 2011 to 2019 Explorer
14 Explorer Stabilizer Bar links
Old Oct 21, 2019 | 10:31 AM
Mark2002's Avatar
Mark2002
I have a 2014 XLT with 20" wheels (low profile tires) and I just started noticing a clunking sound in the front end over bumps. Even minor changes in the road surface will produce a rattling or clunking sound on both sides of the front end. My Grand Cherokee made similar noises and I was able to fix it by replacing the stabilizer bar links, so I am hoping it will work with the Ford too. Does anyone have any opinions on how to verify this is the problem? I tried moving the link by hand but it seems tight. The bushings look pretty wimpy and 62k miles. No grease fitting on the stock links either. The Moogs have grease fitting.
Thanks.
Old Oct 23, 2019 | 11:34 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
At 62,000 miles, lack of a grease fitting shouldn't be an issue.
Disclaimer: Safety blah blah blah, perform at your own risk, yada yada.
Have someone gently push down on it over and over while you get your ear close to investigate. It could be a few things under there.
Old Nov 19, 2019 | 01:18 PM
Mark2002's Avatar
Mark2002
UPDATE: I still have not had a chance to replace the stabilizer links, but the front end clunking sounds worse. NJ roads have a bump or pothole every 10 feet or so, so I am not surprised that the front end needs help after 62k miles.
Old Dec 28, 2019 | 08:20 PM
Mark2002's Avatar
Mark2002
UPDATE: I finally had a chance to replace the stabilizer bar links on the Explorer. The driver side bottom mount was "loosey goosey" so I think that was the culprit. The Moog links improved the handling and I can now keep them greased properly. My rattle and bump noise has gone away. Took me about 20 minutes per side.
Old Dec 31, 2019 | 12:38 AM
CathedralCub
FTE Community Team
Cool!
Thanks for letting us know how it came out!
neilc88
Escape & Escape Hybrid
Jan 23, 2019 12:36 AM
rundm
Aug 22, 2017 04:54 PM
feigerou
1983 - 2012 Ranger & B-Series
Aug 12, 2008 09:32 AM
MR.DAVE
Nov 27, 2006 08:43 PM
KenFromNorCA
Mar 11, 2005 05:47 PM
