Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Front end rattle (not end links, sway bar bushings, tie rods or steering u-joint)
Old 10-14-2018, 07:05 PM
neilc88's Avatar
neilc88
neilc88 is offline
Hi guys,
I have been struggling trying to find the front end rattle over bumpy roads.
2009 Escape 3.0 XLT fwd. 43k miles.
I do feel like I have taken some noises out.
Replaced sway bar stabilizer end links, sway bar bushings, inner and outer tie rods and steering u-joint.
The sound is multiple thuds over slightly bumpy road.
Any tips are greatly appreciated.
Old 10-15-2018, 05:04 PM
simonsi's Avatar
simonsi
simonsi is offline
Wow - you have changed all the likely stuff, try and see if it is CV-related, does it get better or worse if under drive load over the road?
Other possibilities (in no particular order):
Front strut internals?
Poor quality/faulty new parts already replaced?
Hub nut torqued correctly?
Brake shoes moving?
Old 10-16-2018, 06:41 AM
neilc88's Avatar
neilc88
neilc88 is offline
simonsi,
Thank you for the reply. I have to come clean on the fix. It was the left lower sway bar end link that was loose. I replaced this a few months ago and don't know if I didn't tighten all the way or if it came loose. I added blue lock tight this time.
I found it by having my son rock the Escape back and forth. I could hear it then saw it moving.
All is good now. Looking back I probably should have checked this sooner but oh well.
Old 10-17-2018, 03:49 PM
simonsi's Avatar
simonsi
simonsi is offline
Glad it was an easy fix :-)
Old 01-23-2019, 12:36 AM
rustydailey's Avatar
rustydailey
rustydailey is offline
I had this same issue. Drove me crazy until we found it.
rundm
08-22-2017 04:54 PM
Bigpapa346
12-07-2013 02:29 PM
Shattered
10-29-2013 09:43 PM
adamroy
1999 to 2016 Super Duty
05-04-2011 01:57 PM
trinogt
1983 - 2012 Ranger & B-Series
03-07-2009 04:06 PM
Quick Reply: Front end rattle (not end links, sway bar bushings, tie rods or steering u-joint)
