Front sway bar links?
Old Aug 10, 2008 | 08:32 PM
feigerou's Avatar
feigerou
Trying to diagnose a front end sound on my 1998 2WD Ranger. When backing up and turning left, a 'pop' sound comes from the front right wheel / suspension. This sound won't happen repeatedly, just once, and it also doesn't happen when turning right and backing up. I just replaced the front right ball joints because they were worn (left were replaced a couple years ago), and the sound is still there.
Am I right in thinking the sway bar link might be the problem? If it is worn, then it might bind and then pop into place??
What do you think?
Old Aug 11, 2008 | 03:10 PM
SSuperchargd's Avatar
SSuperchargd
sway bar end links, my 03 did the same thing, get polyeurethane ones
Old Aug 11, 2008 | 05:04 PM
pgw85706's Avatar
pgw85706
Agreed. Check your sway bar connecting links. See the thread below.
Welcome to FTE.
https://www.ford-trucks.com/forums/6...bar-links.html
Old Aug 12, 2008 | 09:32 AM
feigerou's Avatar
feigerou
After I posted I remembered that the sway bar links were actually replaced a couple of years ago. I checked them out last night also, and they look to be in good condition - no cracks and bushings look solid. Could this 'pop' sound also be caused by a tie rod end? If the tie rod ends were worn out they could bind and pop also.
nagetech
Mar 24, 2017 11:49 AM
DidieX
May 2, 2016 07:23 AM
pablocruz69
Nov 16, 2015 09:37 PM
tracyclifton
Feb 9, 2015 09:41 PM
AllaboutMPG
Aug 12, 2014 09:32 PM
