1964 Lower Passenger door hinge?
Old Oct 18, 2019 | 05:50 PM
PRattenbury's Avatar
PRattenbury
Hello, working on a 1964 F250 cab. Passenger side lower door hinge did not seem to be attached to anything any more. Upon further investigation, I found out the lower door hinge was in fact not attached to anything anymore. The inner vertical piece inside the A pillar is rusted away. And, the hinge half that attaches to said piece is rusted apart. I can replace the steel panel in there. But I will need a replacement hinge half. Anyone know where I can score one? Not the half that's inside the door, the half that attaches to the a-pillar? Thanks for any advice.
Old Oct 18, 2019 | 06:13 PM
resonateur's Avatar
resonateur
In order to replace the backup piece and cage, you will have to cut into the kick panel. Replacement hinges are reproduced and “imported” or you can probably find an original here on FTE, junkyard or eBay. There will be no hinge half....you will get the whole thing.
Old Oct 18, 2019 | 06:15 PM
spurredon's Avatar
spurredon
They are around, here's a not so great example: https://www.ebay.com/i/283549151228?...SABEgKpSPD_BwE
Old Oct 18, 2019 | 09:33 PM
resonateur's Avatar
resonateur
Less $$ than repro’s. Although, at near 65 years old, I doubt that they are free of wobble....at 65 years old, I’m certainly not free of wobble.
Old Oct 19, 2019 | 01:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C4TZ-8122800-A .. Door Hinge / Obsolete
1964 F100/1100 & N500/1100 Upper & Lower and Right & Left before serial number 490,001 // 1964 F100/1100 & N500/1100 Right & Left Lower from serial number 490,001.
Right & Left Lower: 1965/66 F100/1100 // 1965/69 N500/1100 // 1967/69 F800/1000.
The hinge pin has to be reversed to use it for the left side // Note: 1961/63 F100/1100 & 1963 N500/1100 is different!
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 100 = 800-476-9653.
Old Oct 19, 2019 | 07:40 AM
PRattenbury
Thanks very much! I thought I was getting a fairly solid replacement cab. Not so much! But I'll get it fixed up.
Old Oct 19, 2019 | 11:57 AM
RangerMercMan's Avatar
RangerMercMan
The slick doors are not heavy or long so most of my hinges are in good shape. You can usually get re bushing kits for them. The only hinges I lost were in April 2018 after the snow started melting and then we had a three day deep freeze. It broke both my drivers door hinges in half on my parts truck
Old Oct 19, 2019 | 04:54 PM
PRattenbury
I had the passenger side door that wasn't really swinging open and shut right. The kick panel looks like it was busted out (and rusted out. And I could see the part of the a-pillar below the lower hinge was going to need to be replaced. I had no idea there was a vertical wall inside there that the hinge attached to as well. Probably because it wasn't there any more (rust). So I ended up taking the door off and now I have that whole a-pillar and lower part of the cowl cut up like a Christmas turkey. I went and bought some 16 gage sheet metal and made some templates out of manila folder. Transferred the patterns over to the sheet metal, and then cut them out with the plasma cutter (what a time saver!). I have a lot of cleaning up, grinding and prep work to do. I'm not going to weld much together until I have another lower hinge to mock into place, so I will know all the bolt holes are in the right place. Then a bunch of welding, and more grinding to get it looking passable. Not after a concours resto, just want a solid cab. :-) Then there's the cab mount stiffener under there, the floor pans, and lets not forget our friends the cab corners!
Old Oct 19, 2019 | 06:43 PM
spurredon's Avatar
spurredon
Sounds like all the usual stuff. Glad you can tackle it yourself, it's worth it.
doug64f100
Dec 21, 2018 10:19 AM
Tylus
Aug 15, 2016 10:21 AM
66 twin i
Jan 6, 2008 09:52 AM
omni
Dec 13, 2006 06:36 PM
Brian66
Dec 24, 2003 01:08 PM
