Replacement door hinge???
Old Jan 5, 2008 | 10:22 PM
66 twin i's Avatar
66 twin i
Hi guys i was wondering if anyone knew where to get door hinges. I think mine are bent and i cant get my door to shut. I have done a lot of rebuilding on it to get the new hinge area patch in. The door fits in place but when i close the door the latch pulls it up then when i open it the door drops a little. I put in new pins and it still drops a bit. I have the striker as far down as it goes but that doesnt work. If i lift the door a little when i shut it, it closes fine. Thats where i think the hinges are bent. Any info on where to get hinges or fix the ones i have that would be great. Thanks Justin
Old Jan 6, 2008 | 03:03 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Old used car dealers trick for aligning doors.
Park the vehicle on hard level ground (not dirt or gravel). Get a 5' 2x4...put one end on the ground, the other about 3/4's of the way back on the door sill. Close the door till it comes in contact with the 2x4...then gently push the door up slightly on the wood. Repeat till door closes properly...then tighten the hinges. Do not loosen the hinges beforehand.
1965/66 F100/750 door hinges
1 or 2) C4TZ-8122800-A .. Lower Hinge-Left or Right
1) C4TZ-8122800-B .. Right Upper Hinge
1) C4TZ-8122801-B .. Left Upper Hinge
FTE sponsor Green Sales has Ford NOS (new, old stock) hinges: the R/L lower, and the right upper in stock.
Old Jan 6, 2008 | 09:52 AM
66 twin i's Avatar
66 twin i
Thanks Bill I finally got it!!! I forgot about that trick. I fought that door all day yesterday.
Thanks a million now i can get on to finishing my cab corner and then get started on the floors and cab mounts... Thanks again. Justin
