Fault Code P1443
Old Oct 9, 2003 | 07:43 AM
Roguespirit's Avatar
Roguespirit
Unhappy Fault Code P1443
Check engine light came on, Checked the code and got P1443 -Evaporative purge flow sensor fault. Now what? I can find any remove and replace information on any of the items. (Purge flow PF sensor, Purge solenoid, Vapor management valve VMV) Can you guys help? Is this something I can do myself or do I need to pay the shop $$$$$$$ to do it?
Old Oct 9, 2003 | 07:52 AM
Rockledge's Avatar
Rockledge
Hello, welcome to FTE!
This thread might help: EVAP Emissions Control System
Old Oct 9, 2003 | 08:39 AM
Roguespirit
Thumbs up Appreciate it.......
Thanks for the reply, by any chance know where I can find the R&R info on changing the parts out? Thanks again for the reply
Old Oct 10, 2003 | 12:00 AM
zoti's Avatar
zoti
I had the same code on my 96 B2300. I bought a replacement valve and sensor and installed them myself.
First check to see if there are any leaks on the line between the evap canister and the engine. If your's is a 2.3 liter as well then the canister will be just under the battery. From the canister there will be 2 lines coming out. One goes to the gas tank. The other goes through a special hose (special because it's wider in diamater on the canister side and smaller on the other) to the control valve. The vlave has a 2 wire power connector. Then there's another hose that goes to the sensor (with a 3 wire connector) and from it there's another hose to the engine.
Sensor goes for around $50 at ford.
Valve is about $27.
Special hose is $19.
The whole set (I think it's the valve, sensor and 3 hoses) is around $90.
So, First check if it's the hoses (my special hose was a bit cracked but not leaking. I replaced it anyway). Then check the valve. Connect it to an external 12v power. If it opens then it's ok and it's probably the sensor. The sensor should change resistance when there is air flow through it. If you need to know the values let me know. I have the chilton manual but I'm lazy to check at the moment.
If I had to put my money I'd say it's the sensor. They are known to go bad.
Hope this helps.
Zoti
87&97Aerostrar
Aerostar
May 3, 2017 09:49 PM
jmccracken1214
Sep 21, 2016 07:50 PM
Supercab
Apr 25, 2011 09:28 AM
tscinta
Aerostar
Oct 12, 2008 09:17 PM
Beothuck
Nov 9, 2006 11:24 PM
