RV Wire Colors
Any ideas gentlemen and/or ladies? Please don't tell me to simply put 'em where they were..... I'm scared to do that.
I know it’s confusing but there are a lot of separate electrical systems on an RV. Some require 24 volts and some require 12. Some are wired to run off the batteries and the generator, and some are wired into switches that are normally in an open/neutral state (which may be why they don’t ohm out).
Unless you want to unhook each wire one at a time and then start flipping switches and walking through the RV trying to figure out exactly what it powers, don’t stress about it.
Steve
Steve
I have serviced a few RV’s (basic maintenance on engine and generator, changed batteries, brake work, etc) but don’t have a wealth of knowledge about them in general.
I’m curious how you can know nothing is 24 volt when you don’t know what year and make the RV is. The OP states there’s seemingly opposing wire colors hooked up to the terminals (white to positive, red to negative) so to me that’s an indication there could be a few circuits that are wired in series to the batteries, meaning they would be pulling 24 volts.
On that note, I realize the OP doesn’t specify changing multiple batteries, but the experience I have with them, there’s always a battery to start the engine and then there’s at least one additional battery for auxiliary systems. These batteries are usually connected to each other somehow, if for no other reason than to be charging from the alternator and/or generator.
And....GO TEACHER GO!!!
There is nothing in an RV that requires 24 volts and there is no 24 volt charging system, that I have ever seen. The OP has a very basic electrical system in his Arctic Fox fifth wheel as noted in his signature. He may have two batteries, but they are either two 12s in parallel or two 6s in series. When the batteries tie together on a motorhome to feed off the alternator, they connect through a relay in parallel, not series.
Even in the big diesel pushers I serviced did not have 12s wired in series nor do any of the towables. The genny, if he had one is 12-volts. For 30 years I was the lead tech at three different dealerships, I can't do a chainsaw or a semi, but I can wire RVs and have done it from scratch when folks disconnect all six batteries in a diesel pusher and don't know how to put them back together.
I was not trying to step on your toes. I just didn't want Bud to possibly get more confused than he already may be. I think you initial advice was spot on. Unless there is a reason to think something is wrong, it probably is just fine and even if he makes a mistake, there is darn little that can happen and I have had more than one customer wire their batteries backward. Folks think something will explode, but the most common thing that happens is something or a lot of things don't work.
Steve
One drawback to viewing this site on my phone is it doesn’t show the signatures so I couldn’t have known that was his RV without looking at this thread from my laptop.
I appreciate the variety of experience I get at my shop (I once had the fun task of troubleshooting a 1968 Harley Davidson electric golf cart) but it often leaves me in a position of giving very general advice rather than knowing the specifics of any particular vehicle. I was caught on the 24 volt comment because a few months ago I replaced 2 deep cycle batteries on a customer’s RV and it did have a jumper from the negative on one battery to the positive on the other. I thought they were 12 volt batteries but I’m not gonna trust my memory on that - my boss said replace those batteries, so that’s what I did.
I didn’t think you were stepping on my toes - I just couldn’t help but notice your screen name and jump on the chance to hijack this thread.
After a day of no responses I called Northwood and got the info I needed and found I had simply "LOST" the hot lead to the main slide control box. Northwood did help me determine what wires were what tho and it helped a lot ! With the help of a 12/6 v probe (the kind with a sharp pointed end and a light in the other) I opened the Slide Control panel and found no 12v at the point where there was supposed to be. Tracing that hot lead back towards the battery (wires through the body wall) I finally saw I hadn't connected that wire to the battery !! It had been lost in the rats nest of wiring. Simple end to a panic situation. BTW, I found out that as I age I am much quicker to doubt myself when something goes amiss. I must remember to us the saying of "KISS". Hope you all know what that is.
Another thing you young guys obviously don't know (or remember) when it is said that when you "OHM OUT" wires, you are actually doing is checking resistance in that or those wires. What is the symbol for resistance Steve??
I know the symbol, but my keyboard doesn't.
The reason I suggested voltage is that is a faster way to check the "hots" and I thought that was you point of confusion. Actually this type of problem is one of the easiest one to troubleshoot because, as you discovered, the solution is so often right in front of us. Operator error, as the industry calls it, it perhaps the #1 cause of problems for all of use. Once you understand how one fiver is connected, you basically understand all of them so Bud, the next time it is your call!
And don't go calling us old guys old!!
Steve
What to do, what to do? I know I could go underneath, cut a hole in the belly and ratchet the slide in, but that takes an eternity and is such a pain the manufacturer that thought it up should be shot. Fortunately, however, most manufacturers group the switches and my power awning switch was right next to my slide switch. I had some 16 ga wire (too small to carry the slide motor load for long, but enough to carry the load briefly). so with my wife pushing the button if you will and me holding the jumper in place, we ran the slide in a few seconds at a time. Do it too longs and the wire gets hot, melts the insulation, ouch. On the next trip I had to run new wires replacing what the mouse had chewed!
Morale here is even when it seems like a tragedy, it almost never is.
) - there is nothing like common sense and a lot of experience !
