First oil change
Old Oct 13, 2019 | 08:06 AM
tibadoe's Avatar
tibadoe
Most OEM filters from factory are gorilla tight 99.9% of the time. After the first removal and new filter installed - no issue. I used to use channel locks until I found this:
Better fit and grip around the filter. Many brands available to fit any budget.
Old Oct 13, 2019 | 08:46 AM
harmanrk's Avatar
harmanrk
Originally Posted by FractureCritical
Yeah, but why have it be different? On a $4 filter? Doesn’t make any sense.
Black only label vs three color for the store Motorcrafts, might be a difference of 5 cents per filter. That's 5 cents every minute across every assembly plant. These are the corners that the bean counters look at, on every part on the vehicle.
Old Oct 13, 2019 | 09:20 AM
Flyct's Avatar
Flyct
FTE Community Team
+1. I bought and use this $11 version. Makes filter removal very easy
Amazon Amazon
Old Oct 13, 2019 | 10:26 AM
fordman19762003's Avatar
fordman19762003
Originally Posted by ForCal
How did you know?
Was getting a long crank on every cold start first thing in the morning, rest of the day it was fine. Was told the engine will not start until there is enough oil pressure for the phasers to work. I was told to hold the throttle down when I turn the key to let the engine crank but not start so it would build oil pressure. Then let off the throttle and start like normal, if it fired right up the long crank could be due to a couple things.
1. Bad ADBV causing the oil to bleed back down
2. Normal function so the computer can check the location of the cam and or build pressure.
I replaced the filter and I don't get the long cranks every cold start like before. I still get them once in awhile which I guess is normal.
Old Oct 13, 2019 | 10:28 AM
fordman19762003
Originally Posted by harmanrk
Not sure what you mean by 'non-branded'. It is clearly marked FoMoCo Ford Motor Company. Filters bought for the factory don't get fancy three color labels.
I was told the factory uses filters made by Champion which are different than the consumer line of filters made by Purolator.
Old Oct 13, 2019 | 04:22 PM
Jointasset's Avatar
Jointasset
1300 miles, 3 months old. Had to use channel locks to crush and remove the factory oil filter. Petty gripe, but certainly invites doubts elsewhere.
Same thing happened to me today when I changed my oil, broke out the channel locks. One key piece of information though is that I have done all of my oil changes. I really didn’t think I had hand tightened it to much but apparently I was wrong.
EpicCowlick
May 25, 2017 12:12 AM
17 Oaks
Apr 26, 2017 02:14 PM
Pool Runner
2009 - 2014 F150
Mar 25, 2014 07:39 AM
sand_fiend
17
Nov 26, 2013 08:22 PM
sjwelds
2004 - 2008 F150
Jul 9, 2009 12:35 PM
