Leaf springs, 2WD
Old Oct 8, 2019 | 01:24 PM
niko20's Avatar
niko20
Leaf springs, 2WD
I have a 1979 F350 2WD ..I believe it's a trailer or camper special (144" wheelbase, has side mount spare tire)
The passenger side sags almost 1/2 inch on the right side compared to the left. I found by measuring from frame to body that it really looks like it's because the springs on the right side are sagging a bit. I put some spring extenders on the front coil spring, and that mostly fixes up the front, but the rear still sags on the right (1/2 inch or so).
I was thinking of just getting new leaf springs, but it seems like most I find online are for 4x4 and I have a 4x2
Any good recommendations?
I don't plan on ever carrying a camper
Old Oct 8, 2019 | 03:40 PM
ATS Junior's Avatar
ATS Junior
SPONSOR
Are your springs 2.25” wide? How many leafs does each spring have? If your truck is equipped with upper overload springs, don’t include those in the leaf count.
Old Oct 8, 2019 | 05:53 PM
niko20's Avatar
niko20
Yep 2.25" on the top leaf, about 2.5" bottom leaf. 8 leaves
Old Oct 8, 2019 | 10:06 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by niko20
I have a 1979 F350 2WD .. It's a Trailer or Camper Special (140" wheelbase w/side mount spare tire).
1973/79 F350 Regular Cabs on the 140" wheelbase (2WD only): 1973/76 Super Camper Special / 1973/79 Trailer Special / 1977/79 Camper Special.
Ford dropped "Super" after 1976.
D4TZ-5560-A .. 8 Leaf Rear Spring - 2,550 lbs. load rate / C7TZ-5560-G .. 9 Leaf Rear Spring - 2,725 lbs. load rate / C6TZ-5560-F .. 10 leaf Rear Spring - 3,525 lbs. load rate.
These springs are 2 1/4" wide, 26" > > eye bolt < < 26."
Old Oct 9, 2019 | 09:03 AM
ATS Junior's Avatar
ATS Junior
SPONSOR
Is it 8 leafs or a 7/1? Huge difference in the steel make up and weight capacity.
Old Oct 9, 2019 | 09:21 AM
Mark8man's Avatar
Mark8man
Sagging could also be the spring eye and shackle bushings are worn. Try to find a local truck spring shop. They will be able to determine correct springs to match factory and also check the bushings. I'd be inclined to let them do the work as well because it can be a miserable job especially if you have rusty bolts or don't have the tools/experience for that type of work.
Old Oct 10, 2019 | 07:47 PM
RalphXL's Avatar
RalphXL
I've bought a couple sets of leaf springs from ATS, a bunch of bolts, and a couple sets of shackles too. Good people, nice products, easy to use website, and a discount for members of this site.
Jess
Old Oct 11, 2019 | 10:05 PM
niko20's Avatar
niko20
Sorry guys work got me good this week, haven't been able to check in. Thanks for the great information. I am not sure if it's a 7/1 spring or not. I guess I would go with Number Dummy's info since he is always accurate
I haven't gotten a Marti report so I also don't know if this is a trailer or camper special, I only know it had the extend base with side spare. I am almost thinking it's a trailer special and not a camper special but it has zero emblems for either. So only way to know would be a Marti
Old Oct 12, 2019 | 05:15 AM
Tedster9's Avatar
Tedster9
I second the truck shop advice, shipping will cost a bit for leaf springs, a local truck shop will do everything, so you won't have to track down part #s bushings and bolts and gee gaws, u-bolts etc.
Ben Samways
May 2, 2018 10:34 PM
DeathRangerofDeath
Mar 5, 2016 04:58 PM
1999stroke
Mar 16, 2015 11:21 PM
gopher2
Oct 10, 2012 06:29 PM
BullRidnRenegade
Mar 11, 2012 10:37 PM
