Fuse box lids
Old Oct 7, 2019 | 06:36 PM
Squeak& Destroy's Avatar
Squeak& Destroy
Fuse box lids
I'm missing my fuse box lid, both under the steering wheel and inside the engine bay. Does anyone have a picture of theirs? I'm in a 2000 F250 7.3, CC SB. I'm trying to get my cruise and overhead computer working and hoping it's just a simple fix.
Old Oct 7, 2019 | 09:48 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
The owners manual will tell you. The lid is useless without the manual anyway since the fuses are not labeled under the lid by anything but a number anyway. I always appreciated GM's actual labeling of fuses in the lids.
Old Oct 8, 2019 | 02:38 AM
Squeak& Destroy
Truck didn't come with a user manual. Am I just up the creek then?
Old Oct 8, 2019 | 06:23 AM
seville009's Avatar
seville009
Manuals are online
http://www.fordservicecontent.com/Fo.../00f23og3e.pdf
Old Oct 8, 2019 | 08:03 AM
Squeak& Destroy
Originally Posted by seville009
Thanks so much! Sadly, it's not just a fuse like I'd hoped. Any idea where to go from here?
Old Oct 8, 2019 | 08:31 AM
Fat Diesel's Avatar
Fat Diesel
The CC and the horn are both run off the same relay, I think. When my horn started honking on its own I pulled the relay. The CC stopped working at that point. Maybe that helps?
Old Oct 8, 2019 | 09:24 AM
Squeak& Destroy
Horn works fine, if they're connected then one should affect the other, correct? And I was just complaining about that little "wussy" horn on this big, burly truck the other day! 🤣🤣
Old Oct 14, 2019 | 03:40 PM
SaintITC's Avatar
SaintITC
The CC had a recall associated with it. There's a brake fluid pressure sender on the master cylinder somewhere that would fail. Without that the CC doesn't work, and some chance of an engine fire. Or so the TSB claimed. Or something like that.
Old Oct 14, 2019 | 03:44 PM
Squeak& Destroy
I replaced that this morning and still nothing. I'm at a loss here and I really want my cruise control. 8hr drives just aren't as fun when you gotta hold the skinny pedal constantly.
Old Oct 14, 2019 | 04:15 PM
SaintITC's Avatar
SaintITC
Do you have power seats? I used to use a bit of broomstick between the seat and the go pedal on an E350 cargo van I drove a lot years ago...
Old Oct 14, 2019 | 04:47 PM
Walleye Hunter's Avatar
Walleye Hunter
Good old fashioned hillbilly CC right there.
RenoHuskerDu
Dec 5, 2018 04:15 PM
2007FEH
Escape & Escape Hybrid
Sep 12, 2018 05:14 PM
shortbusted
Jan 9, 2012 04:24 PM
purecty
Electrical Systems/Wiring
Sep 6, 2007 05:34 PM
BroncoIIMan
Bronco II
Nov 24, 2003 12:02 AM
