Sponsored by: Auxito
What is the 7700 pkg?
Old Oct 8, 2003 | 08:00 PM
Multipierce's Avatar
Multipierce
what is the 7700 pkg?
Dube
Old Oct 8, 2003 | 10:29 PM
LxMan1's Avatar
LxMan1
It is an extra payload option. Inbetween a F150 6500GVW and an F250 8800GVW.
It is a F150 with a 7700 Gross Vehicle Weight.
The 2003 brochure says that they also come with a beefed up tranny.
Jimmy
Oh yeah, they have 7 lug wheels too.
Jimmy
Old Oct 8, 2003 | 11:12 PM
aldridgec's Avatar
aldridgec
Bigger trans, bigger rear, stronger wheels, tires, frame, better cooling standard, 5.4L only
Old Oct 9, 2003 | 12:51 AM
hood's Avatar
hood
Multipierce:
This is from the 03 Ford F-150 brochure:
7,700 lbs. Payload Group A: Increases GVWR to 7,700 lbs. and GCWR to 13,500 lbs. (Available Only on 139" Wheelbase Styleside Regular Cab or SuperCab 4X2 and 4X4 with 5.4L V8).
Includes: Larger Brakes, Higher Capacity 7-Lug 16" Wheels and LT245 Tires (All-Season on 4X2; All-Terrain on 4X4), Heavy-Duty Frame, Heavy-Duty Shock Absorbers and Springs, Heavy-duty 72 amp-hr. Battery, Radiator and Auxilary Transmission Oil Cooler Upgrade, 3.73 Axle Ratio, 4X4 Models Include Snowplow Capability.
I am very pleased with mine!
-hooD
Old Oct 9, 2003 | 12:58 AM
Tim Ervin's Avatar
Tim Ervin
This model is very much like the '97-'99 F250 LD. I just bought a '98 4x4 F250 LD. I don't know much about it yet though. I do have a '99 brochure though and everything mentioned above is similar to my F250LD. My truck is rated at 7200 lbs though. It's 4x4 tow package but no snowplow package (although one might have been welded on once before). Truck was manuf. in Canada went to Michigan, MO, and now in TX.
Old Oct 9, 2003 | 06:35 AM
aldridgec's Avatar
aldridgec
The snowplow prep package is kinda rolled in. Its not the actual snowplow, but a front axle rating high enough for use with a snow plow.
The F250's differ because they could have quite a few differences that lower the GVW and GCVW.
Old Oct 9, 2003 | 09:10 AM
Tim Ervin's Avatar
Tim Ervin
I understand the snow plow didn't come with the truck just as a trailer didn't. I don't have the snow plow package because they have 4150 front GAWR while mine is only 3600 lbs. Something was welded on to the front at one time and the truck was in Michigan until 35K miles. The F250LD had 2 payload packages #1 and #2. #1 is rated at 7200 lbs and #2 is rated at 7700 lbs. I'm just mentioning the F250LD as a way of evolution for the F150 7700. No F150 had a rating higher than 6600 in 1999. And the F250LD was discontinued or at least the badging was changed to F150 7700. There are differences in any models and years. But few trucks have 7 lug wheels. I assure you that these are the same trucks. The trans was upgraded and the engine has more power after '98. But a '97-'99 F250LD would be equal that that years F150 7700 if there had been one. Or the other way around the newer F150 7700 is todays F250LD. Either way I like the truck. It is strong than a half but not as heavy as a SuperDuty. My bro has a "5/8" Silverado 4x4 w/ 5.7L. While it was a decent work truck it isn't as strong as my truck. I still need the HD/SuperDuty just not all the time.
Old Oct 9, 2003 | 04:22 PM
umdstang's Avatar
umdstang
i also like the 7700. like he said it is heavy enough do to a good amount of what the 250 superduty can do without having an enormous truck.
I love mine
Old Oct 9, 2003 | 04:56 PM
Multipierce
Thank you.
Dube
Old Oct 9, 2003 | 09:36 PM
aldridgec's Avatar
aldridgec
Evolution is a good word for it. Line consolidation is another way to look at it.
While the basic major components are the same, frame, cooling, axle (whatever) , the 7700 can only come heavy loaded . Where as you could get a pretty light F250, with a 4.6 etc. In all reality, I think they did it to make things a little easier. The general public seemed confused about the F250 especially once the new SDs came out in 99. Hence the change for the 2000 MY.
Sorry Tim! When you said it may have been welded on there it sounded like you thought it may have come on the truck the same way a trailer hitch comes attached to the truck (as a Tow Package).
Old Oct 10, 2003 | 09:31 AM
markmacd's Avatar
markmacd
The closest I came to owning this kind of truck was them screwing up at the factory and putting the F-150 7700 emblem on the tailgate of my 6250 LOL
Old Oct 12, 2003 | 03:02 PM
kspilkinton's Avatar
kspilkinton
Could be worth some bucks if you still have it. They didn't make very many of these 7700's and they discontinued them as of the 2003 model year (upgraded to a 8200 lb GVWR iirc). Probably less than 200,000 trucks in four years. Sounds like a lot, but when you sell 850-900,000 trucks a year in four years, that's around 20%. Not as rare as some of those one off sports cars, but rare enough for me.
If i have to replace an emblem, I can only imagine how much money I'd have to spend to get it.
-Kerry
93RangerXL4x2
1997 - 2003 F150
41
Apr 24, 2026 11:10 PM
Mickey Bitsko
1997 - 2003 F150
Feb 27, 2017 08:17 AM
Dogmann
Sep 12, 2016 08:07 PM
bigredtruckmi
All Things Towing
Sep 15, 2015 10:46 PM
white 01
Jul 16, 2006 12:50 PM
