F-150 7700?
Old 02-26-2017, 09:12 PM
Mickey Bitsko's Avatar
Mickey Bitsko
Mickey Bitsko is offline
F-150 7700?
After doing a lot of searching and reading numerous official Ford sites I cannot understand what makes a f-150 a 7700.
is it just f-250 LD or the f150 with a HD tow pkg?
Does anyone have a relatively simple explanation?
Old 02-26-2017, 09:37 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
F150 with heavier axles.......... you would have 7 studs per wheel , where the F150 had 5 and the F250 had 8.
Old 02-26-2017, 09:59 PM
Mickey Bitsko
if there's a f150 7700 with heavier axles then what do they call a f-250 light duty? The tow capacities seem minimal IMO.
I think I'm going to settle for a complicated engineering wonder brought to us by Ford.
Old 02-26-2017, 10:57 PM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
The heavy duty tow package is a different option independent of whether or not the truck has 7 lugs.
In 1997 when this body style was new, only the F150 was upgraded and the 1997 F250 with 8 lugs retained the older body style until the release of the extremely successful Super Duty which went on sale in early calendar year 1998 as a 1999 model.
Ford made a weird decision in 1997 to offer the then new F150 body style with a "Heavy Duty Payload Upgrade Pack" that included 7 lug wheels, heavier duty 10.25" rear, stronger 4R100 transmission, bigger brakes, and beefier suspension. And the weird part is that they called it an "F250 Light Duty" in those first couple of years that it was available. Having 2 totally different trucks with completely different body styles both called an F250 on sale at the same time has caused much confusion to people that don't bother to do any research on the matter. It is really pretty simple.
In 1999-2000 Ford dropped the "F250 Light Duty" designation and the 7 lug became the "F150 7700", so named because the GVWR was 7700 pounds. This is a significant payload increase over F150s with 5 lugs. The 7 lug package was available through the next couple of generations of F150 bodied trucks as well. In later generation F150s the GVWR for the 7 lug trucks was more than 7700, but they were simply designated "F150".
It is what it is.
Once people get past
"Why did they...?"
and
"Well they should have..."
And learn about what actually IS, they can easily figure out which truck is which.
Old 02-27-2017, 08:17 AM
Mickey Bitsko
What's confusing is the regular f-150 the f150 7700 and the f-250 LD. I bought a late 99' f150 xlt 5.4 4r70 3:73 LS,
hd tow, 4 wheel discs 9.75 RP, not knowing what I bought I started researching and that's when
​I got got all confused.
Through the original owners manual and Vin I think I figured out the payload which was my original goal.
Thank you Sam I am, for giving a little more insite on the 99'+ SD, I was not aware, so I looked it up and learned something new..
edit; some of the options on my new to me truck where just that " options " that's what triggered my search.
xtal_01
1997 - 2003 F150
07-24-2016 10:29 AM
jimbob134
2009 - 2014 F150
21
01-28-2015 01:10 AM
hotrod4x5
1999 to 2016 Super Duty
03-25-2009 01:58 PM
dcracing
1997 - 2003 F150
03-09-2005 10:38 PM
Ford-man22
1997 - 2003 F150
01-06-2005 02:55 PM
Quick Reply: F-150 7700?
