I’m trying to locate the actual harness that the ECT sensor plugs into. I’ve apparently tucked it away many years ago when I added aftermarket gauges and utilized the existing port on next to the T-Stat.
Is this a single wire or two? I have a couple random single wire plugs tied up, but I believe they were from the stock fuel bowl delete. Does it split off from the main engine harness in the valley? It’s been too many years since I’ve had to hood open on the old truck. Thanks!
