Rapid blinker issue
Old Oct 1, 2019 | 08:52 PM
Mintdezl7.3's Avatar
Mintdezl7.3
Rapid blinker issue
I have a 1997 7.3 f250, when I turn the blinkers on it will blink normal for 1-2 seconds then start rapidly blinking. Could this be a bad ground, rubbing wires, or relay issue? I have no clue, please help me.
Old Oct 1, 2019 | 09:05 PM
Talyn's Avatar
Talyn
got a bulb out somewhere on that blinker side.
Old Oct 2, 2019 | 05:25 AM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE
as William said it could be a bulb burned out.
or someone could have converted the bulbs to LED
Old Oct 2, 2019 | 07:28 AM
Mintdezl7.3
No bulbs are burned out. That’s why I’m having so much difficulty figuring out why it’s doing that
Old Oct 2, 2019 | 08:20 AM
knottyrope's Avatar
knottyrope
replace da blinkah if da incandescent bulbs ah ok
Old Oct 3, 2019 | 07:41 AM
Talyn's Avatar
Talyn
Remember, there are 3 marker bulbs to each headlight. 1 of those 3 being out can cause you the issue.
otherwise you might just have a bad relay.
I went through a bunch of them till I took a chance and got the "heavy duty" one or whatever that looks like it wont fit, Well it works good. hahah and it fits.
Old Oct 3, 2019 | 06:51 PM
Mintdezl7.3
It would have to be bad relay, I went thru all the bulbs yesterday and they were good, and replaced some anyways for the fun of it but still both blinkers are doing it
Old Oct 3, 2019 | 08:55 PM
milkstake's Avatar
milkstake
Check the fluid
Old Oct 4, 2019 | 07:47 AM
Talyn's Avatar
Talyn
I'm trying to remember if there is a fuse under the hood.
But as well, do you have a trailer brake kit?
Possible short there which will cause fast blinker.
Old Oct 4, 2019 | 07:48 AM
Mintdezl7.3
No I dont have trailer brakes. Isn’t the relay right under the dash towards the bottom?
Old Oct 4, 2019 | 07:54 AM
Talyn's Avatar
Talyn
Yeah, the round thing down there. Usually metal, but sometimes plastic.
Old Oct 4, 2019 | 09:56 AM
knottyrope's Avatar
knottyrope
Originally Posted by milkstake
Check the fluid
You are welcome to use my coupon
Old Oct 4, 2019 | 09:51 PM
97-psd's Avatar
97-psd
I only use Motorcraft blinker fluid. The big box store stuff seems to make my blinkers look dull. The OEM really brings out the color.
I would check the flasher relay
Old Oct 5, 2019 | 09:12 AM
tjc transport
i ain't rite
i tried using synthetic blinker fluid, but it leaked out of the cracks in the old wires cause it was thinner.
so i had to flush the system and put authentic Motorcraft blinker fluid back in
Old Oct 6, 2019 | 09:13 PM
867.309's Avatar
867.309
Might have a bent blinker fluid dipstick - shorting out. Be careful with that thing - gentle.
giorgio.fo
Apr 16, 2017 05:55 PM
Ziob
Oct 24, 2016 09:44 AM
gurinder_s_gill
18
Dec 14, 2015 01:43 PM
ac-460
Jul 1, 2012 08:45 AM
parisherj
18
May 9, 2010 01:16 PM
