4R70W shifting problems
Old Oct 6, 2019 | 05:33 AM
sunbelt57's Avatar
sunbelt57
1997 F150 4.6L 4WD - about 271K miles
I was driving along the interstate about 70mph when my transmission quit working. I shifted into N and then back into D and it worked for a few seconds and then quit again. I pulled over and made a few calls, then tried the 4WD shifter. I put it into 4WD high, then back into 2WD and it seems to fix the problem. I turned around and headed for a safer place to park, and when it tried to shift from 1st into 2nd, I felt a clunk and heard a bunch of bad noises. So I ended up towing it back to my garage. I have a friend who says he has a tranny that will fit it and I downloaded a bunch of YT videos on how to remove/install the 4R70W so now I'm wondering what my next step is. I haven't tried driving it w/o the overdrive yet.
Old Oct 9, 2019 | 09:41 AM
jk080's Avatar
jk080
Transmission Rebuilder
You should figure out if you have a transfer case problem or a transmission problem first before replacing the transmission.
pcurtice
13
Mar 16, 2024 11:48 PM
2tonsoffordfun
Mar 10, 2008 10:46 AM
ExplorerMan02
Oct 24, 2007 08:43 PM
PSD350
Nov 10, 2005 08:24 PM
