6-speed
Old Sep 10, 2006 | 10:02 PM
WarWagon's Avatar
WarWagon
6-speed
Other than the obvious..........I wonder if you could make a six speed (four speed plus 2 overdrives) by hooking two NP435 transmissions back to back. Just the weird stuff I think about at night....... Dr. Frankenstien
Old Sep 11, 2006 | 11:59 AM
bigdavesohc's Avatar
bigdavesohc
I don't think you can, as you would need two clutch assemblies to do that.
Old Sep 11, 2006 | 12:14 PM
dcf4x4's Avatar
dcf4x4
Would it be possible to design some sort of hand clutch?
Perhaps using an emergency break handle from a small car?
Old Sep 11, 2006 | 12:51 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
If I recall...there was a thread started here about 1-2 years ago on this very same topic. A lot of talk and theories of how it could be done....
Old Sep 11, 2006 | 01:21 PM
john112deere's Avatar
john112deere
My great grandfather ran a coal and ice business, and, according to my grandfather, had a Model A with two transmissions. This was done to gear it WAY down for plowing and hauling heavy loads around the yard. According to my grandfather, though, the only way it worked was to run the second transmission in reverse. Therefore, it didn't add any extra ratios, just geared that truck way down lower using parts that were laying around the shop.
Old Sep 11, 2006 | 09:31 PM
WarWagon's Avatar
WarWagon
my idea is to joint the two output shafts. The main trans and clutch would be in the normal location and the second one would be backwards from the first. Only one clutch would be needed since when shifting the second trans, the first trans would still be in gear and act as just a mechanical link to the second trans. What it would do, is when both transmissions are in 4th, it would be 1-1, but when you shifted the second trans into 3rd and 2nd, it would be overdrive and double overdrive respectfully. It would mainly come down to a 6 speed with a granny low and double overdrive. Granted, there is some engineering in volved in mating the two transmissions to each other, plus the driveline, but all that aside, I think it would work just fine.
Old Sep 16, 2006 | 12:09 AM
85e150's Avatar
85e150
Of course, you could just buy a 5 or 6 speed trans and DRIVE your truck....
http://www.motivegear.com/tech_info/...nny_guide.html
Old Sep 17, 2006 | 12:16 AM
WarWagon's Avatar
WarWagon
Buy a 5 or 6 speed?.........why stop there. I'll buy a new truck.
Old Sep 19, 2006 | 11:06 PM
85e150's Avatar
85e150
You could put them in line and use taller diff gears or tires. Super reduction with both trans in the lower gears. This is a bit tough on the diff though...
Old Sep 20, 2006 | 09:09 AM
the peppermint's Avatar
the peppermint
I thought of the same idea with opposing tranys, only thing would be to make sure the driveshaft is spinning the right way. you would hate to have all of those gears only in reverse.
Old Sep 20, 2006 | 08:54 PM
WarWagon's Avatar
WarWagon
The driveshaft would be spinning the right way and loading the gear on the proper face. Unless I have overlooked something
Old Sep 20, 2006 | 10:42 PM
the peppermint
I believe your right. Just throwing an idea out there. I have actually thought about doing this before, great minds think alike.
Old Sep 20, 2006 | 11:41 PM
Bdox's Avatar
Bdox
If you connect the output shafts together, you will be driving the coast side of the gear teeth in the second transmission.
And if you are using two four speeds, you would have three overdrive gears. Unless you had a really low ratio in the diff. The two tallest trans gears would probably be unusable. Might work with a very powerful diesel.
A better setup might be to put the two transmissions in line and use a very tall rear end gear and large diameter tires.
Old Sep 21, 2006 | 12:28 AM
aurgathor's Avatar
aurgathor
Most everything is doable, as long as youi got deep pockets and lots of resources to throw at it, but of course that doesn't mean that they are practical, or make much sense.
If you need lots of gears, the ZF5 will work with quite a few engines -- it has granny 1st and OD 5th for a nice, wide ratio. If you need more gears, a gear vendor under or overdrive can get you up to 10 gears that should be enough for most uses. Alternatively, you can get something with 4x4 that has a 4L range, so it effectively doubles the # of gears.
Old Sep 21, 2006 | 12:40 AM
Bdox's Avatar
Bdox
I expect we are just theorizing here.
