Contribution code cylinder 6
Old Oct 2, 2019 | 05:21 PM
David Fehir's Avatar
David Fehir
Got a contribution balance code in cylinder 6 the only sign there's anything wrong is a slight studer when pulling small grades on the highway around 65 70 MPH other than that truck runs great no other issues other than boost fluctuations while accelerating and on occasion I have a rough choppy idle but it comes and goes. I've been told in the past that could be a plugged up EBP sensor. I know other things other than a bad injector can cause a contribution code. If the EBP sensor is clogged can it cause my contribution code? Trucks an 03 studded and deleted. Please help any advice would be greatly appreciated.
Old Oct 2, 2019 | 05:57 PM
Striderwv's Avatar
Striderwv
You could do a buzz test to see if it is the injector. You should hear a click for every cylinder. If #6 does not click then you probably have some stiction. Sometimes they dont click until its cold. My #5 is that way. You can use an oil additive (hot shot, archoil & rev-x) to try and help. If you can read pids, ebp/baro and map should all be similar. That should tell you if the ebp sensor is plugged.
Old Oct 2, 2019 | 06:53 PM
xcrsp440's Avatar
xcrsp440
How many miles on the injectors? And are they stock or aftermarket?
Old Oct 2, 2019 | 07:31 PM
bismic's Avatar
bismic
Assuming they have received the flash update (and almost ALL of them have) .......the 03's do not use the EBP sensor.
Old Oct 3, 2019 | 05:18 PM
David Fehir
So how can I be shore my truck isn't using the EBP sensor?
Old Oct 3, 2019 | 05:19 PM
David Fehir
Number 6 is stock and I couldn't tell you how many miles it has it was in there when I bought the truck 3 years ago.
Old Oct 4, 2019 | 03:46 PM
Striderwv's Avatar
Striderwv
IIRC your icp sensor will be on the rear of the engine and your gpcm will be mounted horizontally.
Old Oct 4, 2019 | 05:24 PM
David Fehir
What is the gpcm and were is it located?
Old Oct 4, 2019 | 07:30 PM
Ford.Dude's Avatar
Ford.Dude
Glow plug control module
Old Oct 4, 2019 | 07:59 PM
David Fehir
I believe my icp sensor is located under my turbo and my glow plug control module is located in the exact position as the one in the picture you posted. Does this mean my EBP sensor is not operable?
Old Oct 4, 2019 | 08:08 PM
bismic's Avatar
bismic
Is your PCM seeing an EBP sensor value ....... ??
(a rhetorical question)
Old Oct 4, 2019 | 08:38 PM
David Fehir
On my torque pro I have a graph for my ebp psi and it never shows any data.
cornstar6207
Sep 14, 2013 02:34 PM
Dozeman
Apr 21, 2013 06:29 AM
mason6540
Oct 18, 2010 04:25 PM
cpnhgnjnky
Jul 7, 2002 07:04 PM
