Need iOS Bluetooth OBD2 tool recommendation
Old Oct 1, 2019 | 04:57 PM
Flyct's Avatar
Flyct
FTE Community Team
I need a recommendation for a Bluetooth OBD2 adapter and iOS app to read fault codes on my 2019 F350 when they come up.
back story; my F350 intermittently will not start first thing in the day and car displays several errors; Blind Spot System Fault, Pre-Collision Assist not available and Cross Track System fault. I’ve captured it on video several times but that’s not good enough to diagnose per the dealership.
The truck was just at the dealership for 8 days and they were unable to duplicate the no-start and faults so they threw up their hands and gave the truck back to me. They said without catching the errors and seeing the faults they don’t know what to do.
So I am looking for an iPhone app and a comparable adapter so I can capture DTC faults when the issue appears. As an alternative an inexpensive plug in scanner to read DTC codes would work.
Any recommendations?
Old Oct 1, 2019 | 06:30 PM
Spoojr's Avatar
Spoojr
OBDLink MX+ OBD2 Bluetooth Scanner for iPhone, Android, and Windows
Amazon Amazon
This and FORScan are the best I’ve found. Fantastic product and integration.
Old Oct 2, 2019 | 12:01 AM
Flyct's Avatar
Flyct
FTE Community Team
Spoojr,
thanks. I just ordered the OBDLink MX+.
I have the OBDLink MX (Not the Plus) that I’ve used for Forscan on the laptop but it can’t be used for iPhone. . OBDLink products are good products.
I considered an inexpensive plug-in OBD2 stand alone reader but I would be connecting and removing it frequently. My concern is that the truck’s OBD2 port pins may spread and get worn out. Leaving in the MX+ all the time should not tax the ports pins. The only time I would remove it is to use Forscan on the laptop to make changes.
Old Oct 2, 2019 | 02:57 PM
GABAR's Avatar
GABAR
Ford Pass should should display fault codes.
Have you checked that?
Old Oct 2, 2019 | 03:07 PM
Flyct's Avatar
Flyct
FTE Community Team
No fault codes in Ford Pass or in memory when dealer connected their laptop.
That’s why I want to be able to read if any DTCs are reported when the truck doesn’t start and faults are displayed on dash display. Having a video of the truck nit starting and the 3 faults displayed on the dash isn’t good enough to troubleshoot per tech.
The video evidence should work if I have to go Lemon Law, but besides this issue the truck is my perfect truck. I’ve successfully lemon lawed 2 other vehicles so I’m aware how to properly of document the process. If I can capture fault codes when truck doesn’t start that would help.
Old Oct 2, 2019 | 08:56 PM
Spoojr's Avatar
Spoojr
I had the same issue with the video not being good enough. The modules save the exact DTC, and tells you which one caused the warning light to be on. (With the help of FORScan light)
I hope you’re able to find what you need. Ever since I plugged it in, it’s never been unplugged.
Steven99
North Carolina Chapter
Mar 18, 2016 08:19 AM
nomadx4
Dec 10, 2012 03:27 PM
renoduckman
Mar 24, 2012 12:03 PM
RobertJohn
Dec 15, 2004 09:34 AM
avking
Nov 14, 2004 09:53 AM
