Another 66 Build
Old Sep 27, 2019 | 08:06 AM
ruger761's Avatar
ruger761
I’m going to have to brush up on my hammer skills as I know the bed has a few spots that need to be taken care of, luckily nothing major. Pulled the speedo cable out last night. Been burnt against the exhaust so it was toast but the gauge itself still works. Still trying to decide what I will do with that once I get the interior painted. Then cleaned up the floor trim. Came out pretty decent for 53 yr old trim. One less thing to have to figure out.
Old Sep 27, 2019 | 02:31 PM
HoneyBadger87's Avatar
HoneyBadger87
Impressive all around. Thank you for posting so much, I started on my own project '66 f100 a couple weeks ago, you're inspiring me to keep at it.
I do intend to start a thread of my own with pics, I'll definitely be looking for intel from the community.
Old Sep 28, 2019 | 04:35 PM
ruger761's Avatar
ruger761
A little more power washing and pickled the windows. Testing what paint/coating I’m going to use on the frame. Give it a few days to harden up to see which I go with. Thankfully pulling the windows didn't reveal any hidden rust issues. Did crack the front window but it’s getting replaced anyways as it’s delaminated on the edges. Saved the trim that will need to be polished up at some point.
Old Oct 7, 2019 | 10:07 PM
ruger761's Avatar
ruger761
Got a little more done tonight and made the shop turn red. Looks like 2-3 layers of paint and some primer.
Second cab corner has a little rust to fix but nothing too bad.
Top op of the cab is in great shape only 1 antenna hole to weld up.
Old Oct 8, 2019 | 03:46 PM
Farnsworth's Avatar
Farnsworth
It looks great!
Now come over and sand on mine please.
Old Oct 8, 2019 | 09:31 PM
ruger761's Avatar
ruger761
Thank! It’s a lot of work to sand it down, it’s a good thing the fenders hood doors and bed are getting blasted.
Made a little more red dust tonight. Little more detail work to go. Then I’ll finally strip the interior.
Old Oct 8, 2019 | 10:07 PM
65navyf100's Avatar
65navyf100
Looking great! Can't wait to see more! Out of curiosity what are you using to sand it?
Old Oct 9, 2019 | 06:04 AM
ruger761's Avatar
ruger761
Polycarbide abrasive wheels on a grinder along with scotch brite pads on a die grinder. Just have to make sure you move a lot and give the panels time to cool while your stripping the paint off. Depending on the layers it can take a few passes cooling in between to get it all stripped off.
Old Oct 9, 2019 | 12:44 PM
dubya TF's Avatar
dubya TF
Ever try aircraft stripper? It takes time to let it work and can get messy but there's no dust and no chance of heat warping the body panels. I've found that JASCO is the best brand. I use empty coffee cans to store and toss out the waste when I scrape it off the metal.
Old Oct 9, 2019 | 01:33 PM
ruger761's Avatar
ruger761
I though about going that route especially since my wife just now went through a round of plane repaints at work and knows exactly what they were using but went with what I knew how to do. Used oven cleaner in the past on tractors. The old stuff was amazing but the new cleaner isn't worth bringing home. Few more hours on the small detail stuff and I will have the exterior where I want it to be, just taking it day by day. I have set a goal of having it painted by February/March we'll see if I can hit that or not. Edit: Guess I should say painted but not back together.
Old Oct 11, 2019 | 01:17 PM
HoneyBadger87
Ruger, earlier you mentioned that you only had to cut two bolts off when you removed the bed. Were there rivets as well?
Old Oct 11, 2019 | 04:07 PM
ruger761's Avatar
ruger761
It had 3 rows of carriage bolts (6 total) then the back row by the tail gate were standard bolts. Just too rusty to come loose so I cut those.
Old Oct 11, 2019 | 10:07 PM
  #28
ruger761's Avatar
ruger761
Ok so couldn’t take it anymore had do clean up a little and let the truck run a little bit.
Red was everywhere in the shop. Put the big fans in the door and got the leaf blower out. Got the majority of it outa there. Pay no attention to the messy shelves.
Time to pull the seat. Broke 1 seat belt bolt which I’ll have to drill out later.
No telling what this seat was out of. Had a few spacers under it.
No big surprises under, just the patches the other guy already welded in.
Tank pulled. Be a while before it starts again. Let it run until the carb ran dry. Now time to get it cleaned up for some lizard skin and some kinda sound mat. Dash is next in line.
Old Oct 13, 2019 | 08:40 PM
  #29
ruger761's Avatar
ruger761
Interior stripped and clean up started. Few holes to weld up and fix the radio hack job cut out.
Old Oct 14, 2019 | 01:02 PM
  #30
ruger761's Avatar
ruger761
Forgot to mention, as I was pulling the shifter boot off and the shifter, I found the majority of the shifter slop. It had a roll pinned connection with some O-rings an plastic pin bushings that are wore. My guess they wanted to dampen any vibrations going up the shifter. Easy fix once I get to putting it back together that is.
I did have one question though, is it normal for the steering shaft to slide in and out on the column once removed from the rag joint or could the aftermarket steering wheel hub be causing that?
