“EOT” Engine Oil Temperature too cold
Old Sep 23, 2019 | 12:18 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Try deleting the TP formula you got from Tugly and use the Power Stroke EOT included with TP.
Plan C is remove TP from the device, reinstall and start fresh.
TP is pretty flaky in my experience and I prefer Forscan, but TP is the shiny one...
Old Sep 23, 2019 | 12:41 PM
MiamiPSD's Avatar
MiamiPSD
OK...Deleted the TP formula I was using and set up the one for Powerstroke that came with TP.
NOW...its working correctly giving me the correct information. What I can't understand is that looking at the PID editor, the PS PID information max value is 300 which I can change to 250 but the unit type is C?
I thought it needed to be F*
Old Sep 23, 2019 | 12:42 PM
MiamiPSD's Avatar
MiamiPSD
Here is what I have from past threads on EOT PID:
Short Name: EOT
PID: 221310
Units: °F
Max/Min: 250.0/0.0
Equation: (((A*256)+B)/100)-40
I run about 180-190 in winter and 190-210 in summer (empty). For those still equipped
with EPBVs, it can activate up to about 145-150 degrees F - it is best go easy on the throttle
(on all 7.3Ls) until you get your EOT above that point. You may hear the injectors act "a
little odd" as the EOT passes through 100 degrees F. For those wanting the Engine Coolant
Temperature (ECT), get a separate gauge or handheld infrared/laser thermometer. You will
not find it on the OBDII port.
Old Sep 23, 2019 | 01:00 PM
MiamiPSD's Avatar
MiamiPSD
Anyway......Thank you all for your assistance getting this corrected.
Old Sep 24, 2019 | 07:17 AM
Tugly's Avatar
Tugly
Short Name: EOT
PID: 221310
Units: °F
Oops.... This is exactly why I make no claim to having it perfected. When we program the individual PID, we tell it what scale the results are in. The formula is to make the results in degrees C, so we have to use that. The other settings in torque translate it to degrees F automatically. I can't fix the old posts, but I my latest stuff has downloads with the correct configuration - plus I guess I'm about due to make a 2020 Torque Pro PID list.
My profound apologies to you for the cause of consternation.
Old Sep 24, 2019 | 07:33 AM
MiamiPSD's Avatar
MiamiPSD
Tugly, no apologies necessary. If anything, I am to blame of not understanding more about PID’s and how they work.
As always, thank you for your contribution to this forum......
Old Sep 24, 2019 | 09:43 AM
Sous's Avatar
Sous
FTE Emeritus
@Tugly as a quick fix action before the 2020 Torque Pro PID list comes out, I can help you correct the old post.
Let me know...
Old Sep 24, 2019 | 10:14 AM
Tugly's Avatar
Tugly
Many people would benefit from that correction. I would also appreciate it - to prevent a guilt complex that leaves me in bed all day, playing Angry Birds on my phone and eating bon-bons.
Old Sep 24, 2019 | 10:23 AM
Sous's Avatar
Sous
FTE Emeritus
Sending you a PM...
Old Sep 26, 2019 | 06:07 AM
Tugly's Avatar
Tugly
OK... now I can say I have no idea what @MiamiPSD was talking about After going back to the old posts - they all look fine to me. Of course... that's because @Sous enabled me to fix the formula. Thanks for bringing that to my attention George.
Old Sep 26, 2019 | 11:38 AM
RA101725's Avatar
RA101725
Banned
I live in South Florida where temperature and humidity is always between 80-95 degrees and I can’t seem to get my engine oil temperature measured with torque pro over 98* unloaded.
This weekend I took a drive to the west coast (Naples) which is approx. 110 miles and my EOT’s would not go over 96*
I have read everywhere that this is too cold and I should be somewhere around 180*. What going on that I can’t see higher eot temps? For the record, my trans temp was only 148* during my ride over to Naples.
It should run somewhere between 195-205 F at sustained highway speeds with no trailer but ambient temperature extremes could get it to run a little less or more than that. And it will run less than that in stop and go driving. Also will depend somewhat on which T-stat you have. The stock one opens at 195F. I have a 203F from Dieselsite and Mishimoto makes a 205F. I have heard anything over 230F oil temps is no-buenoville. Obviously which oil you use is a factor. Higher end synthetic oils are more tolerant of higher temps
Old Sep 27, 2019 | 09:24 AM
BBslider001's Avatar
BBslider001
Only the ZF6 equipped trucks are capable of reading coolant temperature via PID.
Whoa wait, what? Do tell! I wonder if my Edge would show this PID? That would be great.
Old Sep 27, 2019 | 09:27 AM
  #28
BBslider001
There is NOTHING wrong with bon bons Rich.....or Angry Birds really.
Old Sep 27, 2019 | 09:59 AM
  #29
AllaboutMPG's Avatar
AllaboutMPG
never mind. helps when you read both pages
Old Jan 21, 2020 | 06:34 PM
  #30
Brian Hanks's Avatar
Brian Hanks
This makes me wonder about mine. It is not near that low, so it has me confused. Can’t be Celsius. In 30° weather today I ran 30 miles at 70 mph on the interstate and I was still at only 155°F.. came from inside insulated garage Ar 60F at startup. Measured on cts2. Could I have a bad thermostat or something? I would think that would be enough to get it up to operating temperature. Runs smooth as can be.
I may need to hook my Bluetooth up and do a comparison with Forscan ...course I had it but didn’t think of it till now.
SpencerS
Jan 16, 2017 12:14 PM
billbot
Jan 2, 2016 08:36 PM
Farmboypowerstroke
May 23, 2012 09:35 AM
gearloose1
Oil & Lubrication
Dec 22, 2009 07:33 PM
RR4E
1983 - 2012 Ranger & B-Series
19
Dec 17, 2004 03:56 PM
