FE428 engine tilt
Old Sep 19, 2019 | 06:03 PM
demonwaif5's Avatar
demonwaif5
FE428 engine tilt
Hey guys,
Lurker for a while, thanks for all the great info. It's been truly valuable for my build.
Details on build:
1974 F100 4x4 frame, 1966 FE428 (built buy FE Specialties in Auburn, CA.), 1950 F1 cab.
The truck had these bones and now I'm doing a RestoMod. We ran into a issue with the engine perches. Before we tore down and removed the motor, we never looked at how the engine sat on the perches. It appears that the driver side perches are ~1 in lower than the passenger side. The frame is level and square so something is up with the perches. We initially thought it was an issue with new aftermarket mounts but when we swapped out the original perches and new motor mounts the issue was the same.
Anyone experience this?
Old Sep 20, 2019 | 02:42 AM
VitaminC's Avatar
VitaminC
That doesn’t sound right.
I have a 76 f250 4x4 with a non original HD 390 (428 block under bored). It sits level in my truck with the original FE engine mounts.
Old Sep 20, 2019 | 07:17 AM
somethingclever's Avatar
somethingclever
needs to sit level...measure on china wall
Old Sep 20, 2019 | 03:19 PM
demonwaif5's Avatar
demonwaif5
VitaminC- Thanks for the picture!
For all intents and purposes, if the motor and the mounts/perches (aren't bent) are what they say they are... the only logical thing is the frame somehow takes a dive on the driver side.
somethingclever- what's 'measure on china wall' mean?
Old Sep 20, 2019 | 04:26 PM
flowney's Avatar
flowney
A level engine is relative to the frame. The natural stance of the frame (level, raked, etc.) should be matched with a level carb. Thus, one should use a level or inclinometer to measure the intake manual carb mounting surface both front to back and side to side. Adjust mounts to maintain those measurements. Variables to control ahead of this include unequal tire height, spring sag, etc. One way to do that is to use jack stands to get the frame level side to side as well as the front to back incline, if any.
Old Sep 20, 2019 | 04:58 PM
demonwaif5's Avatar
demonwaif5
Here are some images of the tear down!! Hard to tell from the angle the image was taken. The engine looks pretty level to me, so do the perches.
Old Sep 20, 2019 | 05:39 PM
VitaminC's Avatar
VitaminC
Strange. Whenever I have problems like this it is usually something stupid that I did wrong.
So I usually double check the simple things first.
Did the passenger side motor mount drop all the way down in the perch?
Maybe try swapping the original mounts side to side and see if the engine levels out?
Old Sep 20, 2019 | 05:41 PM
VitaminC's Avatar
VitaminC
From your second picture the hole in the drivers side perch definitely looks lower to me.
Old Sep 20, 2019 | 06:24 PM
demonwaif5's Avatar
demonwaif5
VitaminC- I know! The DS perch seems too flat. The NP435 mounting bolts look tilted too. Does your DS perch look similar to mine?
I dont know what was done before and the gremlins are showing their faces.
Old Sep 20, 2019 | 06:33 PM
ford390gashog's Avatar
ford390gashog
Looks fine to me, you will notice all Fords site with the engine to the left and the rear angled downward. None of these trucks had a engine that sat level. You need this for weight offset and driveshaft angle.
Old Sep 20, 2019 | 07:26 PM
VitaminC's Avatar
VitaminC
Here are shots of my previous motor as I took it out. FE 360
Engine sits level
Holes in the perches look level to me...
Old Sep 20, 2019 | 08:01 PM
demonwaif5's Avatar
demonwaif5
HAHAHA VitaminC- that motor looks tilted! Same motor perch angles...
ford390gashog dropping some knowledge!!
I guess this is situation normal?
Old Sep 21, 2019 | 12:02 AM
VitaminC's Avatar
VitaminC
One man’s tilted is another man’s level...
Red Rascal
Nov 29, 2017 12:17 PM
41505379
Jun 23, 2014 01:48 PM
bjmayberry2
Aug 14, 2013 07:26 AM
Kyles Flathead
19
Feb 22, 2012 10:44 PM
twise
May 19, 2009 06:45 PM
