Frame Question
Old Aug 13, 2013 | 04:56 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Frame Question
Oh what fun with POs!!!!
NEED YOUR HELP ON HIS ONE
As some of you may know I have been cleaning up my Panels frame but today I ran across this.
This is my motor crossmember (not original)
and there is also a transmission crossmember (not original) didn't take a picture of it but it's not as heavy duty as the motor crossmember.
Since the PO HACKED the old crossmember, I guess to install the C4 Is it really doing anything structurally? I'd think not and if not can I remove it leaving the trans and motor crossmembers to take its place??
Again, I'd appreciate your input on this one
Old Aug 13, 2013 | 07:12 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
I'm not as familiar with the '56 panel as I am with the '53 F100.
On the '53, the cross member that supports the rear of the engine (at the bell housing) also provides radial support to the frame to prevent the weight of the cab from twisting it. I've seen people remove it for an engine swap, and not heard any complaints, but I've always wondered if there was something going on they don't know about.
Your mileage may vary.
Old Aug 13, 2013 | 07:39 PM
crazy wheel's Avatar
crazy wheel
The engine cross member on my 54 Pickup had been cut out. And a 302/FMX installed. Homemade, cobbled up engine and transmission mounts.
Having said that, the next cross brace towards the rear, under the cab, had cracked. I assume that it cracked due to the extra stress put on it from the engine cross member being cut out.
I repaired the cracked brace.
Then I reinstalled the engine and transmission using pre-made engine and trans mounts from D.C. Both mounts are cross member style.
Old Aug 13, 2013 | 09:07 PM
bjmayberry2
If you get a chance can you snap a few pictures of your mounts?
Old Aug 13, 2013 | 09:38 PM
crazy wheel
I'll try to remember to get some pictures of it.
In the meantime....
Here is a link to the engine mount.
Engine Mount Kit | Dennis Carpenter Ford Restoration Parts
Sorry, I can not find the transmission cross member mount in the on line catalog
Old Aug 13, 2013 | 09:43 PM
bjmayberry2
Mine looks every bit as heavy as that one.
Old Aug 14, 2013 | 07:26 AM
crazy wheel
I agree, that one looks well built
suprchunk
23
May 1, 2018 06:26 PM
Red Rascal
Nov 29, 2017 12:17 PM
AustinZentz
33
Oct 18, 2014 06:17 PM
AmericanROCKBREAD!
16
Dec 7, 2010 01:44 PM
1957F100
Mar 18, 2010 07:41 PM
