Y block timing pointer
Old Oct 10, 2019 | 04:04 PM
  #46
rio68's Avatar
rio68
Originally Posted by charliemccraney
600cfm is definitely more than a stock 272 needs. Holley offer a 390 and 465. The carburetors that would have come with the 4v manifold are around 390 so 390 will be sufficient but 465 will be good if other bolt on mods might be applied. Either is still probably more than the 272 actually needs.
Another good one could be the Summit 500 carb. While it is more than needed, it has adjustable air bleeds which means that it should be able to be tuned very well for the engine. This is a feature that is not typically found in lower end carburetors and makes it suitable for a wider range of performance than a typical carburetor without adjustable air bleeds.
We'll have to change carb at some point but looks like the smaller ones are priced more than the bigger
ones strange deal....found mark on damper for timing....got timing set on 9 degrees initial runs good
hope it stays that way. Getting where we need to be thank goodness.
phurst
Mar 1, 2011 04:25 PM
Orange '63
Aug 21, 2008 11:40 AM
rkotila
1978 - 1996 Big Bronco
Nov 13, 2006 09:12 AM
jesse
Nov 20, 1999 08:45 PM
